ABS
Old Aug 17, 2017 | 09:17 AM
Travers's Avatar
Default ABS
hi I have a 1998 XJ8. can anyone tell me if having the brake pipes renewed would cause the abs ,traction and stability faults to appear. I have replaced the abs sensor. The code wont clear with diagnostics. nopower from sensor to cpu ? unit. might this be a cable fault?
Old Aug 17, 2017 | 09:36 AM
motorcarman's Avatar
You need to post in the X308 section of the forum.
https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/
More help from the people that own/repair these cars.
You will also need a more specialized diagnostic device to read C codes from the ABS module.
bob
Old Aug 27, 2017 | 05:27 PM
Welcome to the forum Travers,
I've moved your question from X-Type to X308 forum. Members here with the same model will be able to help.
Old Aug 27, 2017 | 07:28 PM
Daim's Avatar
What code do you have? There are quite a few refering to the ABS and all have to interpretated differently...
quartetchiang
Feb 12, 2017 07:36 AM
bullittandy
Feb 6, 2017 09:35 AM
blackonblackXtype05
Jan 11, 2017 10:45 PM
wymjym
Jan 5, 2017 02:23 AM
JagXV6
Jun 9, 2013 06:51 AM
