AC barely blows
Old Sep 14, 2019 | 03:58 PM
brian2891's Avatar
Default AC barely blows
I have a 2002 XJR and have an issue with the AC not blowing hard. Even with the AC on high, I can feel the the AC lightly blowing cold air if I stick my hand up to the vent, but that's about it. Someone mentioned that I shouold replace my blower motor resistor, but I don't know where it is located. Does anyone have any insight into this?
Thanks,
Brian
Old Sep 14, 2019 | 04:58 PM
motorcarman's Avatar
My bet is one of the blowers is INOP!!
bob
Old Sep 14, 2019 | 06:21 PM
Addicted2boost's Avatar
I agree with bob but I have a shot of the blower resistor just so you know where they’re located.
It’s in the same location on both fans.
if you want to know where the fans are located, it’s in my post for the evaporator that I made this morning.
Old Sep 14, 2019 | 08:34 PM
Lady Penelope's Avatar
Your 2 fuses for :
Left fan. - # 11 / 20 amp LH heelboard fuse box
Right fan . # 11 / 20 amp RH heelboard fuse box
You can swap the relays located both in the right heelboard area , it's the 2 stacked above and below each other
See page 77
http://www.jagrepair.com/images/Auto.../jagxj2002.pdf
Old Sep 14, 2019 | 09:50 PM
brian2891's Avatar
Thanks everyone! I checked the fuses in the rear heel boards and they are both in good condition. What is the best way to determine if the blower motors are inop? I took out the pocket to the left of the steering wheel to feel the driver's side blower. When I touched it, I felt very little vibration from internal components moving that. Not sure if that means it's good or bad. How do I access the passenger's side blower motor? Is it just a matter of removing the glove box?
Old Sep 15, 2019 | 08:23 AM
SIMPLE!!!!!
Turn the blowers ON and then pull each fuse to see if one (or both) shut OFF!!
bob
Old Sep 15, 2019 | 10:43 AM
Before removing the right side and the glove box area swap the relays as the glove box area can be trouble putting back together and adjusting the items out to look proper alignment
Keep in mind that the blower is a high current item and as it fails ( if thats the case ) it will ruin the relay internal contacts , the nature of the beast
The X300 and X308 has a front control panel self test with codes that may give you some information
See page 110
http://www.jagrepair.com/images/Trai...des/703_SG.pdf
The codes are in this TSB , this one for the X300 as the X308 is the same Denso manufacture brand system so should be the same codes
http://www.jagrepair.com/images/TSB/...stem%20DTC.pdf
Old Sep 15, 2019 | 09:47 PM
brian2891's Avatar
The passenger's side blower motor isn't working. Thanks for all the help and advice y'all gave me! I ended up pulling the #11 fuse in the driver's side heel board and noticed that neither blower was running. Bob, you're advice was spot on! Now it's just a matter of looking through the JTIS manual and figuring out how to get the old blower motor out to replace it with the one that I ordered. Thanks again to all of you for the assistance.
Old Sep 15, 2019 | 11:31 PM
M. Stojanovic's Avatar
The problem may not be in the motor but in its "resistor" which is actually an electronic motor speed controller. I would rate the probability of the controller's electronics failing as higher than the motor failing. You can test the blower motor if you disconnect the controller (4-pin connector), plug-in a wire into the socket of the loom side connector to which the ORANGE wire of the controller connects, switch the AC and the ignition "on" and touch the ground with the inserted wire. If the motor is good, it will run at full speed. The fan speed controller looks like this:
Old Aug 9, 2025 | 06:52 PM
pmcint's Avatar
It's probably the brushes
Old Aug 10, 2025 | 09:37 AM
Mark waite's Avatar
Default Blower motors
Thanks everyone on this thread this problem could be the cause of my weak air conditioner instead of the pollen filter so this gives me another possibility to investigate thank you for your advice. I will post again with my results
Old Aug 10, 2025 | 12:06 PM
Even when a cabin filter (if present) is clogged, enabling RECIRC will eliminate that from the airflow circuit.
Old Aug 12, 2025 | 06:19 AM
Mark waite's Avatar
Default Weak air con
Hi there members I removed the fuse in the drivers side heel board fuse box and it made no difference to the blowers I also removed the passenger side which stopped the blowers al together so I believe the problem is with the drivers side blower or resister
thank you all for your contributions on this string
Old Aug 18, 2025 | 06:21 AM
Mark waite's Avatar
Default Ac barely blows
Hi everyone the mechanic tells me it’s the resistor on the passenger side motor. The Jaguar parts dealer wants to charge me £258.60 for a new resistor does anyone know the part number or anyone that sells unbranded ones in the uk I would appreciate it very much.
thankyou mark
Old Aug 18, 2025 | 08:29 AM
Hooli's Avatar
Blimey are they still on these?
I had that issue on a XJ40 years ago.
I'd guess it's JLM11959 from looking at https://parts.jaguarlandroverclassic.../brand/jaguar/
BTW, I see you're Doncaster. Who are you using to work on it? I know two specialists around here, I used to use the Jag Specialist at Armthorpe but he'd no longer got the special tool to do the front springs so I went to Bell Lane Garage, South Kirkby who seems cheaper & happy to source 2nd hand bits as needed.
Old Aug 18, 2025 | 08:56 AM
Mark waite's Avatar
Hi Brian
I have used bells once before but I thought they were quite expensive. I now use Andy candlers o thorn rd behind the Wheatley hotel the owner there is called Kev he has worked on all my jags now for about 15 years he has full programme and I have never managed to beat him and his prices are very reasonable I would recommend him to anyone. Also thank you so much for your help with this problem I will try and get the correct one the dealer at Leeds wanted £258.60 for the resister
Old Aug 18, 2025 | 09:11 AM
Mark waite's Avatar
I am very sorry hooli I called you Brian the thread somehow went back to the start which was Brian so please accept my apologies and thank you once more for the information
Kind regards mark
Old Aug 18, 2025 | 10:42 AM
Hooli's Avatar
Originally Posted by Mark waite
Hi Brian
Not heard of them, I'll have to remember as I thought Bell Lane was quite cheap compared to the other place!
Old Aug 18, 2025 | 10:43 AM
Hooli's Avatar
Kind regards mark
No problem Dave, it's easy done
Old Aug 20, 2025 | 04:05 AM
Mark waite's Avatar
Thank you to everyone who contributed to this problem I have now diagnosed the issue. It was the resistor on the passenger side apparently a very awkward strip out and I have also managed to source an oem part from Coventry to replace so again thank you everyone
kind regards
mark
Neil1664
Sep 1, 2013 12:45 PM
tford
US Northeast
May 31, 2011 11:03 AM
MLRocafella85
Jan 25, 2011 09:33 AM
