AJ26 custom ECU tuning?
Old Aug 29, 2012 | 11:49 PM
adam699's Avatar
Default AJ26 custom ECU tuning?
I've been poking around but I can't find any concrete info on anyone who can tap into my ECU to tune it.
Has anyone actually done this? What ECU is in my car?
Old Aug 30, 2012 | 04:46 AM
Sean B's Avatar
I originally had an ecu remapped by Paramount - when I did the rebuild I looked into getting the new one done. The guys I contacted 'flashremapping' use Viezu files....they contacted the guy who used to work for Paramount to locate the file, turned out the 4.0 files where 'unstable' and couldn't do it....if only the 4.2 ECU's where compatible as they're a much better unit for re-mapping. I don't know of any in the USA but I'll bet they use Viezu?
If you look in the boot your ECU will be listed on the VCATS list. Something like LNG1410AD
Old Aug 30, 2012 | 10:26 AM
adam699's Avatar
Isn't the AJ26 and AJ27 ECU different?
I'm trying to figure out if any other car uses the AJ26 ECU.
Old Aug 30, 2012 | 10:44 AM
Sean B's Avatar
Custom engine management is the route then - I doubt Jaguar/Ford used the ecu for other applications, just XJR/XKR.
Maybe a Tech3/Visteon/AEM/r2g2 type system, then a manual gearbox is easy, and no issues with ratio's. Just the BCM to defeat via the box I mentioned.
How far do you want to develop the car?
Old Aug 30, 2012 | 02:23 PM
XJR-99's Avatar
Eurotoys is maybe the only(? ) one which offers ECU tunes for our X308 Denso ( Denso LNC1410CA in MY99 S/C )ECUs at the moment: Jaguar XJR ECU Tuning Upgrade 4.0L S/C 98-03 . I wanted to keep the orginal one as untouchable and added Arden's additional ECU ( dont' ask the price : ) . Not sure which one is better....
Old Aug 30, 2012 | 06:36 PM
adam699's Avatar
I reached out to Mike earlier today. I guess the tune he's got is intended for stockish cars. I told him my upgrades and he recommended a piggyback for custom tuning.
Old Sep 27, 2012 | 02:11 PM
sailorspapa's Avatar
Default Exhaust Question
Adam, do you still have your stock XJ exhaust for sale? Please shoot me an email and let me know either way at:
jbbetts@fuse.net
Thanks, Jeff
Old Sep 30, 2012 | 11:02 PM
Count Iblis's Avatar
The AJ26 and AJ27 ECU are both Denso units. They're also both 16 bit while the AJ33 4.2 is 32 bit. The early AJ33 4.2 is a air flow based calibration while the later ones are torque based.
Be thankful that the AJ26 unit ISN'T torque based as it only makes things alot harder to remap.
I would be happy to help remap your car for you. I know a vehicle chassis dyno in the western chicagoland area and was involved in some of the mapping of the original cars.
Old Oct 1, 2012 | 03:47 AM
Sean B's Avatar
Now that's an offer I'd take up if I lived in Chi Town
Go for it guys...
Old Oct 1, 2012 | 04:18 AM
Cambo's Avatar
Question for the Count;
Could you explain in a little more detail about the ECU for the AJ33? Where is the cutoff for early & later models with the airflow/torque based calibration? Is AJ33 airflow and AJ34 torque? When was the changeover from AJ33 to AJ34?
I've been in contact with several tuners in the UK about tuning my '05 XJR, everyone seems to point back towards the Alientech J-Tag or K-Tag devices, as a "must" for tuning the Denso ECU, but unsurprisingly nobody i've spoken to has actually done an XJR....
From what you've mentioned here there might be another way for the AJ33?
Old Oct 1, 2012 | 01:53 PM
adam699's Avatar
That would be awesome
Old Oct 1, 2012 | 02:02 PM
SteveM's Avatar
Count, would you be able to tune for a larger MAF and larger fuel injectors?
Old Nov 25, 2012 | 09:55 AM
In theory all can be done, you just need some sort of piggy back controller. My original plan was to use and adapt unichip. After you have access to the appropriate variables you just need a sensible methodology to map and access to a dyno (I use some friends in Plainfield) making sure you know enough about engines to put a sensible range of values in.
I appologise that I haven't responded or been available recently.
It's not a good time at all for me at work
http://www.chicagobusiness.com/artic...-very-bad-year
Navistar CEO Is Ousted As Board Hires Former Textron Boss To Steer Through Crisis - Forbes
We've had to lay people off and there have been big changes. I've been focusing on this and the Jag lays dormant in my garage with the new 15 HU project diff in pieces in a box ( I still need to get the old crown wheel out).
I even paid someone to change the timing chain on my M88/3 BMW M6.
I'm not sure when I'll be able to get back into Jags. Take care
MrWhite
19
Jun 14, 2022 07:49 PM
waynepaulj
Oct 2, 2015 04:05 PM
Johncy2000
Oct 2, 2015 01:05 AM
sdelliott58
Oct 1, 2015 01:46 AM
