Battery Drains after sitting a bit
Old Apr 9, 2021 | 09:29 AM
Djmcmann's Avatar
Question Battery Drains after sitting a bit
I have a 2000 Jaguar XJ8 Vanden Plas - it has a new battery and I have had the alternator checked. However, if I let the car sit a week or so, since it is a Sunday driver, the battery is dead and needs to be jumped off. It is like something is pulling on the battery as it sits in the driveyway. Any thoughts on how to check this and see what is pulling a charge (if that is the case)
Thanks in advance for any help.
Old Apr 9, 2021 | 10:35 AM
JagV8's Avatar
There are a lot of threads on drains with advice so maybe read a few.
Old Apr 9, 2021 | 10:39 AM
King Charles's Avatar
On my 3rd X308 and each shared this issue lol.
Old Apr 10, 2021 | 11:14 PM
Highhorse's Avatar
Pay attention to posts 6 & 8 in this thread as you review it.... https://www.jaguarforums.com/forum/x...-drain-182813/
Old Apr 11, 2021 | 03:00 PM
Parker 2's Avatar
When you remove the key a switch makes from pin 4 to pin 5 which starts a security module countdown of agreements of other components of the car
Until the security module gets the agreements it will stay in a higher power drain mode
Once the agreements are met the security module goes into sleep mode which is a much lower power drain on the battery
One of the agreements is the driver exit position of the steering column
To overcome this you can switch the column control from automatic to off
There are different approaches to freeing up the ignition barrel in / out switch
Some clean first before spray lube ( graphite best ) as old lube can thicken and be stiff
Old Apr 11, 2021 | 04:07 PM
Jhartz's Avatar
Look to the glove box and the light in the boot as likely suspects.
Old Apr 11, 2021 | 04:36 PM
motorcarman's Avatar
TheX308 takes about 20 minutes to POWER DOWN and 'go to sleep'. (about 30ma nominal draw)
It takes a while to see the battery current drop step-by-step from several amps to 30ma.
I usually open the doors and the boot lid but close all the latches to simulate CLOSED.
Put an ammeter from the negative battery terminal to the negative cable and watch the amps/current drop incrementally.
Pulling fuses and network connectors/modules can 'wake-the-car' and you have to start all over again to see what circuit the constant drain is on. (USUALLY the SCP network)
Dallas Rockford
Dec 26, 2020 03:29 AM
TheTerrible Keleb
Jan 6, 2019 10:04 PM
Smithauction
Aug 22, 2017 01:49 PM
beema7453
Oct 24, 2013 04:37 PM
MrBoss88
May 17, 2011 08:25 PM
