Brake pads
Old May 11, 2017 | 04:31 AM
Sacho's Avatar
Default Brake pads
2000 xjr. Any suggestions on disc brake pad brands. Low dust.Thanks.
Old May 11, 2017 | 05:22 AM
Sean B's Avatar
Hi, are your brakes standard as some came with a Brembo option?
For standard I've used Pagid and found them very good. EBC make decent pads also. Saying that, OEM are good.
Some forum members have used Akebono ceramics mainly for low dust.
Have a search as this has been discussed at length!
Hope that helps.
Old May 12, 2017 | 11:31 PM
VR6Guru's Avatar
Just installed a set of Stop Tech rotors with Akebono Pads. I love the combination. The pads stop as good if not better than oem and with virtually no dust.
wheels are clean all the time now
Old May 13, 2017 | 07:13 AM
Dan Hiatt's Avatar
I run Akebono ceramics for daily driving: low dust, no squeal, fine stopping power, lack much of an initial "bite" when braking. I am trying EBC Yellow Stuff pads for the track, and they are way more aggressive, but have other characteristics (dust, squeal, etc.) that aren't as welcome on the street.
Old May 13, 2017 | 07:21 PM
cjesse444's Avatar
Just did EBC reds and Rotors.Fantastic
Old May 13, 2017 | 08:59 PM
harvest14's Avatar
+1 on Akebono
Used them on my last 3 Jaguars, all x308s. One XJ8 and 2 XJRs. I use them with Brembo rotors. I also used the Akebono pads on my old BMW and Volvo. I have liked them for a long time.
Old May 14, 2017 | 07:26 PM
grandell's Avatar
Another +1 for Akebonos. Great 'daily drive' pads, very low dust, but beware they overheat easily if you push them, eg track work, 3+ consecutive high speed stops etc
Old May 22, 2017 | 10:19 AM
Finn's Avatar
Any experiences of Ferodo Premier pads as OEM type replacement pads?
I ordered today a set of Brembo discs but Ferodos seem to be only pads in the country.
