Broken Lug Nut - How To Remove?
Old Jun 23, 2021 | 03:44 PM
silversurfer1221's Avatar
Default Broken Lug Nut - How To Remove?
Hello!
So, I was removing my driver's side front tire to do some work (replace the air suspension compressor) and had a few stuck lug nuts. I applied some rust dissolving stuff, let it sit, then got to work with a breaker bar. Three of the lugs came loose fairly easily, one had to be cranked a bit. But the last one ... the final one ... it broke. Here's a few photos:
Sorry if I don't have the correct words for this, but as you can see from the top photo, the "cap" of the lug snapped off, leaving the bottom part still on the bolt (see second image). The question is - how do I remove the remaining part of the lug nut? So far, I am letting this soak overnight in the rust dissolver stuff to help. My thought is to use a flat-head screwdriver and a hammer to slowly knock it loose in the direction it would turn to be screwed off (counter-clockwise). Is this the best course of action? I have limited tools. Any help would be greatly appreciated. Thanks in advance.
Old Jun 23, 2021 | 06:46 PM
nilanium's Avatar
Is it only the straight part that's seized on the stud? As in, the flange and washer came off with the hex head?
What I'm getting at... can you remove the rest of the lug nuts then take the wheel off?
Old Jun 23, 2021 | 08:21 PM
There is still a threaded part that is still on the post. So, I was assuming I'd have to find a way to screw that off. If you look at the top photo, the top lug ... that long piece that sticks out? That's threaded all the way to the end. And that piece is still on the post. I'm assuming that that piece, due to the angle at the end, is a bit larger than the hole that fits over the post and, as a result, I don't think I can just slide the wheel off. It's late here and the car is not off the ground at the moment. So, I'll give it a shot in the morning.
Old Jun 23, 2021 | 11:45 PM
M. Stojanovic's Avatar
The cylindrical part of the wheel nut is not larger, at any point, than the hole in the wheel. It is actually very slightly smaller (for snug fit) but, if the nut is overtightened, it will deform the hole (compress the aluminium) causing the hole to get somewhat smaller and jam around the cylinder of the nut. You will have to wiggle the wheel until it comes off then you may need to carefully rim the hole to reinstate its original diameter.
Old Jun 24, 2021 | 01:27 PM
Jhartz's Avatar
Any good machine shop can remove the broken stud and replace it. Where in Virginia; if Norfolk area, Abacus Racing can do it for you. Put the wheel back on (or lug nuts if wheel is still attached) and drive it over to a good shop that extract the old . . . the trouble with working on old cars is -- they are old and rust and corrosion are mortal enemies of both the car and the mechanic . . .
Old Jun 24, 2021 | 07:41 PM
cat_as_trophy's Avatar
There is still a threaded part that is still on the post. So, I was assuming I'd have to find a way to screw that off . . .
Nope . . . unless you have some really weird wheels, the 5 holes are simple drillings of parallel diameter right through full thickness of wheel material. The nut is threaded to the stud . . . not the wheel!
Also, I see no evidence of broken stud, so I suggest you disregard that advice. Your pic shows the broken bit looking like a diametrical spacer between stud thread and wheel drilling! Simple task to wiggle, persuade, or perhaps with temp (and loosely applied) nut on an opposing stud, pull the wheel.off. It will slide off, leaving the broken nose of the nut still threaded on the undamaged stud. Remove that with vice-grip pliers. Keep it is as simple as it sounds!
Best wishes,
Old Jun 28, 2021 | 03:13 AM
kansanbrit's Avatar
The wheel should come off then you will probably have to cut the broken piece to remove it from the stud or if you have gas available you can get it red hot then unscrew it.
Old Jun 28, 2021 | 10:31 AM
Jhartz's Avatar
Re-examining the photos, I agree with Cat: you should be able to pull the wheel off. A small pipe wrench would then help in screwing the broken part from the nut off the stud.
Old Jul 4, 2021 | 11:42 AM
steven300's Avatar
there are special impact sockets that grip as you push in tight and reverse
Old Jul 4, 2021 | 12:35 PM
motorcarman's Avatar
The X308 does NOT have a suspension compressor!!!!
Old Jul 4, 2021 | 01:07 PM
xalty's Avatar
i think that’s a lug nut from an x350
get M12x1.5 mag lug nuts for a toyota
Old Jul 4, 2021 | 08:44 PM
The ORIGINAL POST indicated that the work was part of the suspension compressor job.
Old Jul 9, 2021 | 09:17 AM
Vauxi's Avatar
To my eye only the crome cap was broken off ? Just use one size smaller socket to undo nut itself ?
Old Jul 9, 2021 | 09:53 AM
I posted this in the wrong forum. Mine is a X350. Sorry about this. My mistake.
MWave
16
May 18, 2019 05:37 PM
MrWhite
33
Oct 22, 2015 10:29 AM
Vipercf
23
Jun 14, 2015 09:55 AM
sosoguju
May 16, 2015 03:34 PM
X2 Jag
Sep 12, 2007 07:36 PM
