Cam cover gasket set (cheap)
Old Jan 10, 2021 | 05:10 PM
jdbach's Avatar
Default Cam cover gasket set (cheap)
The 1999 XJR I picked up a couple weeks ago had an oil leak from the left up rear cam cover. Removed the cover and the cause was obvious; the gasket had slipped out of the groove and been crushed when the cover was (over)tightened. Looked online and found cover gasket kit was $200+, Looked on EBay and found this set for $31.80. Figured I'd take a chance at that price. Wasn't crazy about the "Made in China" label, but it appears to fit well. Ebay search was for 1999 Jaguar XJR. Invoice when I received it said Ford. No matter. Appears it will work fine.
Old Jan 10, 2021 | 05:49 PM
NBCat's Avatar
Personally, I have not had success with aftermarket gaskets and seals as they tend to fail early. Use the Jaguar OEM parts for longevity and correct fit.
Old Jan 10, 2021 | 07:40 PM
xalty's Avatar
felpro for the lincoln LS fits and works 100% if you ever run into trouble with this set
Old Jan 10, 2021 | 08:13 PM
jdbach's Avatar
Good to know. The Felpro set is still under $50.
wabuegel
Mar 18, 2020 08:13 AM
EsRay
Dec 8, 2017 04:42 AM
aaf8
Jun 30, 2016 09:20 AM
azblindguy
Mar 18, 2014 10:14 PM
Dounraey
May 12, 2011 11:35 PM
