Carbon/Charcoal Canister
Hi all,
My '99 X308 threw up a check engine light so I took it in. I had not noticed previous performance issues. My mechanic tells me the issue is a cracked carbon canister/charcoal canister, one of two on the car. Has anyone else dealt with this issue? Additionally, he noted that the replacement canister seems to be rare.
Thanks all,
Will
Thanks all,
Will
Do you recall what the code was? I'm wondering if I have some issue with the charcoal canisters on my 2000 VDP as it throws odd codes at times and sometimes it has a hard time starting and acts weird for about 30 seconds. When it acts up, the car is wanting to stall and very rough running and i have to press the accelerator to get it to continue running. Once that clears up, it runs completely fine. When it does the hard start, it has a very distinct gasoline smell.
Not at all. But going by the codes mentioned in the thread you lot seem to have a different version of the system as there was no electrical connections to mine.
