CD changer error E-01 SOLVED!!!
Old Nov 4, 2010 | 12:48 PM
2004x-type's Avatar
Default CD changer error E-01 SOLVED!!!
I have an '02 XJR, and when I went to play some cd's, my screen showed an error code. E-01. I called a few guys and they were going to charge me over 300 dollars to get it fixed, or have to buy a new one! So I opened up that little sliding door on the cover, took a flat head screw driver, and shoved it in between the case that holds the CD's, and the player. I lifted up the case a bit, and hit the button, and nothing. I messed with it for a few seconds, and all of a sudden, I got it in the right spot with the right force, and it popped out!!!!!!!! Dont waste your money on a new one, or on having someone else do the same thing. This only took a few seconds! Hopefully it will work for you too
Old Nov 4, 2010 | 05:20 PM
Jagtec1's Avatar
It'll happen again, most likely.
Old Jul 8, 2011 | 09:26 AM
porkenstein's Avatar
This is an older thread but this is what is happening to my changer. I can eject it and put it back in and it works for a while. Is my changer shot or is there a fix?
Old Jul 8, 2011 | 11:13 AM
never mind
Old Dec 25, 2011 | 10:51 PM
MyBabiesXJ6's Avatar
I bought my wife a 93 XJ6/XJ40 Sovereign. I then purchased her a cd changer for
this car which was throwing an error code E01. Our manual said dealer....this awesome site explained potential ways to correct this.
Removal and opening the cd changer, manually ejecting the mag ( by rotating the drive gear for the mag eject with your finger-not prying on it), re-connecting the changer with the mag removed allowing the changer to cycle / reset and send the no mag message to radio, and THEN re-installing cd mag and it works like a dream!!!
Old Dec 26, 2011 | 03:55 AM
Cadillac's Avatar
Good for you , it's good to find cheap solutions rather than expensive replacements
Old Jan 15, 2013 | 08:02 AM
psmart2000's Avatar
As a matter of interest is it still working like a dream. I only ask as my CD changer has just given me a CDC Error and I have opened the unit and manually turned the gear to unblock the error and it works OK for now but is it temporary.
Old Aug 10, 2013 | 08:38 AM
Russell11's Avatar
Hello Guys
Can I get a non Jaguar CD stacker installed in my 2002 S-Type as the original no longer works? I have factory installed satnav.
Best wishes
Russell
Old Apr 28, 2015 | 05:36 AM
Ian E Huntingdon's Avatar
Why?
Old Sep 4, 2017 | 11:58 PM
Josh Adams's Avatar
Thank you soooo much for this info, that's exactly what mine did, I was so bummed I wasn't going to be able to play my CDs.. but it's all fixed now and switches and plays my CDs!!! Thanks again!!!
Old Sep 5, 2017 | 09:23 AM
Mark SF's Avatar
It'll happen again, with greater and greater frequency.
jimforrest (uk)
Feb 28, 2019 06:42 PM
RaceDiagnostics
Apr 4, 2016 04:00 PM
Poet
Oct 2, 2015 09:00 AM
rodneyburnett
Oct 1, 2015 01:41 AM
