centre brake lamp or the "third brake light: one led out
Old May 16, 2012 | 02:43 PM
DJ-Roy's Avatar
Default centre brake lamp or the "third brake light: one led out
There are a few leds in the third brake light ,but one is not working .
Do i have to replace the whole unit ,or can i put a new led/bulb in ?.
Any idea how to take it of the rear shelf ?.
Regards
Old May 16, 2012 | 05:44 PM
Vector's Avatar
I'm sure someone will chime in with JTIS pics, but here is what I know:
(I had to remove mine when I repaired my sub woofer.)
Lay a mirror on the package shelf under the brake light unit. Look from the top and you will see two square 1/2" retainers located on each side of the bottom side of the unit. Push in (up) on these and carefully remove the back portion of the light enclosure. I don't think they are LED's, just regular bulbs.
Be very careful when you do this, take your time and go slow or you will break something, don't ask me how I know......
Vector
Old May 16, 2012 | 10:00 PM
motorcarman's Avatar
They are NOT LEDs, they are 'peanut' bulbs and the bulb holder is probably melted and distorted.
bob gauff
Old May 17, 2012 | 04:14 PM
Sean B's Avatar
They are NOT LEDs.....
bob gauff
Mine are, Bentley OEM. Junked that plastic failure for a decent high level break light.
blah blah blah....
Old May 17, 2012 | 09:55 PM
Looks good!!!
Should last forever!!!
I have several LED high mounted stop lamp strips from different models so I will probably retrofit one to my 1999 XJ8L.
bob gauff
Old May 21, 2012 | 07:36 AM
TerryR's Avatar
Default 1999 XJ8 Third Brake light
bob gauff
Agree with you Bob, mine was not LED, mine was just as you describe, melted and distorted, I bought a replacement unit off E-Bay for approx $20 (Bulb holder & reflectors only, almost new) complete with bulbs, one out, one in, easy and Cheap. Not even worth messing around with anything else. Replacing the bulbs alone,would probably have cost me more.
Old Sep 28, 2012 | 08:44 AM
Tri_motorman's Avatar
Default 2002XK8 Convertible
Last edited by Tri_motorman; Sep 29, 2012 at 08:41 AM. Reason: Posted in wrong section
Old Sep 28, 2012 | 04:50 PM
Vector's Avatar
Tony,
You may want to post your question in the XK8 section. This is the XJ8 sub forum.
Vector
hamilton7550
Jul 30, 2021 11:29 PM
PMKimpton
Aug 3, 2019 08:22 PM
wvanepps
Oct 4, 2015 10:01 AM
Jefro
Sep 15, 2015 01:44 PM
sklimii
Sep 5, 2015 06:04 AM
