checking trans fluid
Old Feb 27, 2015 | 11:08 AM
smith356's Avatar
Default checking trans fluid
I have purchased a dipstick, but I am not sure how to check the fluid level. My Van is neutral gear, engine running. My other car is engine running, park gear. What is the XJR routine ??
Thanks, Jim
Old Feb 28, 2015 | 10:29 AM
motorcarman's Avatar
There are TEMP markings on the dipstick tool.
The procedure is 'Engine running, Park or Neutral'.
bob gauff
Old Mar 4, 2015 | 06:54 PM
D. Fite's Avatar
Where did you get your dip stick assembly/
Thanks, Dave
Old Mar 4, 2015 | 07:41 PM
smith356's Avatar
Default dipstick
Thanks, Dave
You can find them on E-bay - I purchased one for the Mercedes trans / XJR. I'm not sure if XJ8 uses same one. Hopefully someone will join in and supply that info.
Old Mar 4, 2015 | 08:11 PM
Don B's Avatar
I would add a few additional thoughts: In my experience COLD readings are less reliable than HOT readings, so it's a good idea to take the car for a good 20 minute drive before you park it on a level surface, hold your foot on the brake and move the gear shift lever through each gear and leave it long enough for the gear to fully engage, then return the lever to Park and check the fluid level on the dip stick. Being overfull can be as bad as being low, so you want the fluid level exactly on the HOT line. If you accidentally overfill it, you can use an inexpensive fluid transfer pump to remove the extra via the dipstick tube.
Cheers,
Don
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
Bcrary3
Sep 12, 2021 05:41 AM
vsol
Aug 29, 2018 09:46 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
