Cleaning throttle body NOW - 2000 XJ8
Old Aug 13, 2010 | 05:07 PM
stevevaus's Avatar
Default Cleaning throttle body NOW - 2000 XJ8
I'm following these instrux:
http://www.maxperformancecars.com/dm...Clean_MAFS.pdf
to clean the throttle body on my car.
It says to have someone hold the gas pedal down to make the throttle valve "easier to open and clean the throttle valve" however even with the gas pedal depressed it wants to be hard to open - not to mention a local non-jag mechanic said DON'T TOUCH THE VALVE or you'll be in here with more problems.
So how much pressure should be needed to open that valve with the gas pedal pressed? Am I being a wimp?
Sure would appreciate quick response - in the middle of it now.
Old Aug 13, 2010 | 05:41 PM
test point's Avatar
Turn the ignition on without starting. The throttle pedal will then open the valve.
Old Aug 13, 2010 | 07:25 PM
stevevaus's Avatar
thanks - that did the trick - the direction i referred to were very thorough except for that little detail!
Old Sep 4, 2012 | 01:13 PM
my2000xj8's Avatar
I tried to view http://www.maxperformancecars.com/dm...Clean_MAFS.pdf but the link did not work. I have a 2000 XJ8 that keep saying off track and going into limp mode. I cleaned my oxygen sensors and changed my Mass Air Flow sensor and still I'm getting the off track limp mode my codes are p1111,p0175,P171 P0121 I think it has to be my thottle body. Does anyone have a video link with instructions on cleaning the Throttle body before replacing.
Old Sep 4, 2012 | 02:58 PM
jimlombardi's Avatar
hello
I made a pdf file from the max performance cars article on Cleaning XK8/XKR Throttle Body, MAFS, and Part-Load Breather.
Here is the weblink to my mediafire.com account and the PDF file
Cleaning.XK8.Throttle.Body.MAFS.and.Part.Load.Brea ther.pdf
Jim Lombardi
Old Sep 5, 2012 | 10:58 AM
my2000xj8's Avatar
Default cleaning throttle body
Thank you for the PDF I have printed it out and will give it a go tomorrow I'll let you know how it goes..
Thanks again for the info
H20boy
Dec 24, 2024 03:23 PM
Bcrary3
Sep 12, 2021 05:41 AM
Gus
Oct 15, 2019 12:29 PM
ajacks86
Oct 12, 2017 08:51 PM
