Code 1647
Old May 19, 2011 | 02:16 PM
07XKJaguar's Avatar
Default Code 1647
Hi all,
I am needing a little help with this code. Car, 99 XJ8, set code 1647 and according to my codes from JTIS this is the O2 heater circuit or bad ecm. I installed a new O2 sensor and same code set. It sets only after a few cycles of being driven. So I swapped sides just to see if this new O2 sensor could be bad. And of course it set the code for the O2 heater on the other side. This is a Bosch sensor. Is is best just to get the 400.00 from Jaguar or is there something else to check. I swapped out the O2 heater relay and that did not affect it. I checked and I do have power on the white wire to the O2 sensor. Any help would be appreciated.
Old May 19, 2011 | 08:55 PM
07XKJaguar's Avatar
Nevermind, I figured it out. Thanks
Old May 19, 2011 | 10:07 PM
test point's Avatar
Well, are you going to tell us or just leave us to think that you changed the wrong side?
Old May 20, 2011 | 03:02 AM
07XKJaguar's Avatar
Make sure that the wire going into the plug for the heater is actually connected good. This car had a loose wire going into the plug causing an intermitten loss of 12v for the heater. The wire would show voltage once unplugged but when I plugged it back up, the wire would move out just enough not to make contact. Is that good enough?
Old May 20, 2011 | 05:52 AM
sparkenzap's Avatar
Thanks! I bet you are not the only one who has or will have that happen!
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
Terry H
Jul 4, 2017 05:48 PM
JCam
Oct 23, 2016 08:27 PM
