Code P0300 Random/multiple cylinder misfire detected..and others
Old Feb 14, 2023 | 11:37 AM
leaddog11's Avatar
Default Code P0300 Random/multiple cylinder misfire detected..and others
Getting all of these codes at one time. Any ideals. Thanks
Code P)300 Random/multiple cylinder misfire detected..
also getting code p0357 ignition coil G, P0 356 ignition coil F, and P0 351 ignition coil A.
Old Feb 14, 2023 | 12:30 PM
NBCat's Avatar
Helpful to know the kilometres/miles on the vehicle.
What is the battery voltage across the terminals with the ignition in the OFF position when measured with a voltmeter?
What is the fuel pressure?
Are the cam cover seals leaking?
Have the spark plugs been replaced?
Old Feb 16, 2023 | 04:20 PM
leaddog11's Avatar
battery voltage 14.5 running , fuel pressure 41.1 fuel pump replaced 10k miles ago l
75k miles on car
spark plugs and coils replaced about 20k miles ago
cam cover seals not leaking
Old Feb 16, 2023 | 04:50 PM
RandyS's Avatar
I would replace the coils and plugs on the noted cylinders, and realize the other coils are
not far behind.
Old Feb 16, 2023 | 05:04 PM
leaddog11's Avatar
not far behind.
seams so odd 3 coils
or plugs would go out at same time.
Old Feb 17, 2023 | 10:10 AM
RA110623's Avatar
Banned
Ebay ignition coil set
​​​​​​New copper spark plug set unless your plugs are new
vacuum leak if there's any then get silicone hose
Clean the maf
pour techron injector cleaner into the gas tank
Old Feb 17, 2023 | 10:21 AM
NBCat's Avatar
75k miles on car
Voltage needs to be checked with ignition OFF using a voltmeter. Minimum available voltage for all modules to correctly function is 12.6 volts across the terminals.
Remove the spark plugs from the cylinders indicating misfires and inspect for oil in the spark plug wells. Oil fouling is a major cause of ignition coil failures.
Old Feb 17, 2023 | 11:19 AM
leaddog11's Avatar
Thanks. voltage engine off 12.7 engine idle 14.5. sounds about right.
will check for oil.
odd when running and skipping and restricted performance and check engine light showing... When I clear the codes it runs perfect for about 4 seconds .
Old Feb 20, 2023 | 07:47 PM
David N. Warner's Avatar
You could swap some of those coils around and see if the fault follows to the other cylinders. Not and expert but it does sound like coils to me as well....
Old Feb 21, 2023 | 06:35 AM
leaddog11's Avatar
thanks
Old Feb 23, 2023 | 11:18 AM
leaddog11's Avatar
I swapped coils around. same coil codes as before. A, F, G no oil in holes. Will try maf sensor next
Old Mar 17, 2023 | 11:33 AM
leaddog11's Avatar
UPDATE...hard to believe one bad coil could cause all these codes. But that is what it was. Runs great now.
Rex
24
Nov 30, 2018 09:52 AM
Razkid
Mar 8, 2014 03:26 PM
Willyb
Dec 17, 2013 03:51 PM
SirJag
May 27, 2011 08:49 PM
Iconoclast
Nov 29, 2010 01:20 PM
