Codes p1642 and P1646
Old Jul 20, 2010 | 04:41 PM
tool4dgs's Avatar
Default Codes p1642 and P1646
Good afternoon, I have a 02 XJR with codes read from a obdII scanner that come up as P1642 and P1646. The code P1646 is for the fuel pump relay from what I gather. The car itself seems to run okay beyond the fact the gas mileage has gone done a couple of miles per Gallon. Any help would be greatly appreaciated.
Old Jul 20, 2010 | 07:07 PM
H20boy's Avatar
Did a quick search for you, here is what came up. Check out all threads, even just briefly...and the XK8/XKR shares the same engine, so you'll find some good info there also.
Old Jul 20, 2010 | 09:32 PM
test point's Avatar
Matt,
The link doesn't work
Old Jul 21, 2010 | 10:43 AM
jima's Avatar
Pretty sure that P1646 on an '02 model is an O2 sensor, A-bank, upstream. From the Jaguar docs P1642 is a CAN-bus malfunction, I would suggest you make sure your scanner isn't mucking up the CAN-bus and giving you misleading codes before you go any further.
Jim
Old Jul 22, 2010 | 03:57 PM
tool4dgs's Avatar
Default Thanks
Thanks for the info and will go check out the XK forum.
philwarner
Oct 4, 2024 01:37 PM
Steviedee1st
Nov 28, 2023 06:32 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
JCam
Oct 23, 2016 08:27 PM
