coil questions
Old Feb 27, 2020 | 04:28 PM
jeff xj8's Avatar
Default coil questions
hello jaguar enthusiasts,
Can anyone help me with three coil related questions?
2002 XJ8 4 pin coil part # LNE1510AB (164 USD each from jaguar)
1 Is there a way to test These coils? (mass contradictory info on web)
2 Which coil is number 6, also known as "f" (Lots of conflicting info and images out there, dealer did not even know)
3 Is it "penny wise and pound foolish" to buy the cheap replacements? Any experience?
Jeff xj8
2001 (silver) and 2002 (gold) xj8's
Old Feb 27, 2020 | 04:50 PM
Highhorse's Avatar
Dave has some... https://shop.everydayxj.com/XJ8_XJR_...003_s/1841.htm
Old Feb 27, 2020 | 04:51 PM
avern1's Avatar
I have replaced 2 coils in mine both from autozone. Far cheaper than dealer. Others have purchased denso's on ebay and have good results.
Sitting in the vehicle looking at the engine. The left side is number 1 in front then 2, 3, and 4. The right side is 5 in the front and then 6,7, and 8.
Old Feb 27, 2020 | 06:45 PM
RJ237's Avatar
No Vern, when sitting in the vehicle Right side is 1-4 front to back, Left side 5-8.
Old Feb 27, 2020 | 06:50 PM
2001 White XJ8's Avatar
Old Feb 27, 2020 | 06:51 PM
RJ237's Avatar
Thank you, my attempt at posting the diagram didn't work too well.
Old Feb 27, 2020 | 08:44 PM
Highhorse's Avatar
I've done that, I asked a mod to delete it each time I did it...
Old Feb 27, 2020 | 09:04 PM
jeff xj8's Avatar
Thanks for the quick responses.
High Horse, great song, makes me want to drive somewhere right now. Unfortunately both of my xj8's are out of service. Do you know the song, Red Barcheta? another great driving song. Thx for the link.
White xj8, mine is a 2002. How can I know which image to follow.
RJ273, the coil numbers don't correspond to the cylinder numbers in both images. The OBD also gave a designation of "F"
OBD codes were p0306, p1316 p0356, all related to number six.
I removed and tested all the coils and all have consistent OHM measurements.
Im gonna switch the coils right to left and install new plugs hope for the best and see if it generates more codes.
Any thoughts or suggestions?
jeff xj8 , Maryland USA
Old Feb 28, 2020 | 06:26 AM
M. Stojanovic's Avatar
Originally Posted by jeff xj8
...mine is a 2002. How can I know which image to follow.
The images posted by "2001 White XJ8" show that if your car is up to year 2002.5 (first 6 months of the year), you follow the left image; if later, the right image. Here's another image for cars up to 2002.5.
Old Feb 28, 2020 | 09:50 PM
jeff xj8's Avatar
Thanks M. Stojanovic,.
Now I have to figure out my production month, Will that be on the door post sticker?
If changing the plugs and switching around the coils doesn't help, I guess my next suspect would be the ignition control modules?
Malaysia? Sounds exotic.
Old Feb 29, 2020 | 05:47 AM
Easy - just read the engine number. It goes YY MM DD HH mm (mm is minutes) when the completed engine exited the assembly line.
Old Feb 29, 2020 | 07:30 AM
Carnival Kid's Avatar
And you can find your engine # on the left crankcase.
If you use a flashlight and view through the left front wheel-well you can see it behind and between the control arm and the steering knuckle.
Old Feb 29, 2020 | 04:25 PM
jeff xj8's Avatar
I am STOKED !!!!!
With your help I figured out the cylinder / coil numbering system.
I put in new plugs, just because.
I switched the coils left side to right side. (Ohms identical all coils)
Tested it and..... restricted performance, ran worse and codes P0302 , P0352, multiple times.
Notice the pattern??? Coil six (the suspect) was moved to position two which is now throwing codes.
I took a coil from my other xj8 and installed it in number two spot.
Tested it and.....runs like new, no codes nor restricted performance. I am stoked.
Thanks for sharing your expertise and encouragement
Jeff xj8 Maryland USA.
I
JigJag
Nov 27, 2025 02:50 AM
JigJag
Jun 3, 2023 12:42 PM
JameyXJ6
Apr 10, 2012 12:34 AM
gaspoweredteeth
Mar 15, 2009 03:27 PM
