Coolant leak found, but can't figure out what part this is
Old May 1, 2011 | 11:13 PM
Rickcusaf's Avatar
Default Coolant leak found, but can't figure out what part this is
It's leaking coolant and I can't seem to find the parts # for it.
Old May 1, 2011 | 11:59 PM
yeldogt's Avatar
Are you speaking of the connector on the small hose?
I believe you need to buy the whole hose -- not expensive.
Check the other ones carefully -- they get brittel and moving them around while servicing can cause damage
Old May 2, 2011 | 04:12 AM
Rickcusaf's Avatar
I was looking at replacing the whole hose. I just can't seem to find the parts # for it.
Old May 2, 2011 | 08:12 AM
JaguarXJR02's Avatar
I think your answer may be in this thread
https://www.jaguarforums.com/forum/j...numbers-53004/
I had the one from my expansion tank to the coolant crossover bridge connection break a few months ago, these tubes are extremely weak and it's a pain to remove the connectors
good luck
Old May 2, 2011 | 08:32 AM
jimlombardi's Avatar
Default Coolant Expansion Tank Hoses
Hi
I found this information on these Coolant Expansion Tank Hoses in the Jaguar Electronic Parts Catalog (JEPC). Here is a JPEC file I created:
Coolant leak found, but can't figure out what part this is-xjrcoolant-expansion-tank-bleeder-hoses.jpg
I am not sure if the hose you need is #7 or #6 in the diagram. But I think it is #7.
Jim lombardi
BrentGardner
29
Dec 16, 2024 12:13 AM
Rutty
XJ40 ( XJ81 )
Jan 10, 2019 09:47 PM
RaceDiagnostics
Dec 11, 2015 10:12 AM
innzane
Aug 27, 2015 07:58 PM
daro31
Aug 27, 2015 09:26 AM
