Coolant leak under the intake manifold.
So if trans fluid is getting into the cooling system, either the PO did some more fantastically bad work or the bowl is cracked where the fluid goes to to get cooled and its weeping into the cooling system.
I have to ask, you say you may quit Jaguar...why? ...because of someone else's bad work? ...because Jaguar didn't do it.
And will i find coolant inside the transmission?
I really feel bad the jaguar radiator cost about 900$ can't see any special thing about the radiator. i feel the car is start to fail
Advanced auto parts doesn't have one i did search. On eBay all are used one .
Took the car to one old mechanic i know he said i need to pull the radiator and see if its repareable but he said that's easy part what worried him is the transmission hopefully the water didn't reach there.
Update the radiator is fixable. There might be a leak from the engine oil cooler.
There's little amount of water inside the transmission cooler lines he said its not that much but i need to drop the transmission pan and see if there's too much water or no. In best cases will do transmission flush through the lines then new fluid and filter with some hope.
AC0FC
Jun 22, 2024 07:09 AM
