Coolant leak under the intake manifold.
Old Nov 28, 2019 | 05:14 PM
RA110623's Avatar
Banned
Originally Posted by Highhorse
So if trans fluid is getting into the cooling system, either the PO did some more fantastically bad work or the bowl is cracked where the fluid goes to to get cooled and its weeping into the cooling system.
I have to ask, you say you may quit Jaguar...why? ...because of someone else's bad work? ...because Jaguar didn't do it.
Whhich bowl is Is cracked is there a diagram?
And will i find coolant inside the transmission?
I really feel bad the jaguar radiator cost about 900$ can't see any special thing about the radiator. i feel the car is start to fail
Old Nov 28, 2019 | 07:39 PM
RJ237's Avatar
Advance Auto Parts has a new one for $417 and there are several used ones on ebay for less than $200.
Old Nov 28, 2019 | 07:42 PM
Highhorse's Avatar
The broken one is cracked, you need to take it to a radiator shop so they can check it and pressure test it.
Old Nov 28, 2019 | 07:48 PM
scottjh9's Avatar
Take a look at Rock Auto for your radiator, they should have several choices.....quick ship too
Old Nov 29, 2019 | 02:19 AM
RA110623's Avatar
Banned
Advanced auto parts doesn't have one i did search. On eBay all are used one .
Old Nov 29, 2019 | 06:18 AM
Carnival Kid's Avatar
New radiators are available from SNG Barratt, Merriam Jaguar Parts, etc, etc for around $850-$900
A good radiator shop should be able to recondition your existing radiator for less.
Old Nov 29, 2019 | 08:21 AM
RA110623's Avatar
Banned
Took the car to one old mechanic i know he said i need to pull the radiator and see if its repareable but he said that's easy part what worried him is the transmission hopefully the water didn't reach there.
Old Nov 30, 2019 | 12:30 AM
  #28
RA110623's Avatar
Banned
Update the radiator is fixable. There might be a leak from the engine oil cooler.
There's little amount of water inside the transmission cooler lines he said its not that much but i need to drop the transmission pan and see if there's too much water or no. In best cases will do transmission flush through the lines then new fluid and filter with some hope.
AC0FC
Jun 22, 2024 07:09 AM
robot808
Mar 26, 2019 07:09 PM
jrb53
Aug 22, 2015 10:32 AM
dsnyder586
Sep 1, 2013 06:32 AM
kenncl
Feb 7, 2012 02:30 PM
