Cranking but no fire
Old Jul 21, 2016 | 04:37 PM
Dunnie27's Avatar
Default Cranking but no fire
Hi guys I've just got.my late uncle's xj8 sport and when I went to get it the battery was dead so put my spare battery on it and 2 gallons of fresh fuel in it but it turns over ok but won't fire been told these have a fuel cut off some where but any advice will be greatly appreciated
Old Jul 21, 2016 | 04:47 PM
Stu 1986's Avatar
Have you checked to make sure it's not cylinder washed? Also have you checked the fuel pump is operating? The cut off normally only comes on if the car has had a bump.
Old Jul 21, 2016 | 04:59 PM
Dunnie27's Avatar
Hi mate how do I sort out bore wash I'm old skool when it comes to cars I've always had Ford's cortina capri escort so not used to all the electronics in a car
Old Jul 21, 2016 | 06:49 PM
RJ237's Avatar
First determine if you even have fuel at the engine. There is a valve that looks just like a tire valve on the fuel rail. Turn the key on and off and depress the stem of the valve to see if there is fuel pressure. It should spurt out . Cars that have sat often suffer from fuel pump failure.
Old Jul 21, 2016 | 08:28 PM
ericjansen's Avatar
RJ237 is right.
Do an in-forum search on bore wash and on fuel pump failure (I remember a thread on this just some days ago) and you will find plenty of information.
Determine the symptoms first.
Old Jul 22, 2016 | 09:39 AM
Jhartz's Avatar
Check the inertia switch. It is inside on the right footwell just forward of the A-pillar.
See your drivers handbook (or download from the stickies).
Old Jul 22, 2016 | 11:24 AM
Dunnie27's Avatar
Cheers chaps how hard and dear is it to change fuel pump if it's that
NathanDD6
May 3, 2016 05:19 PM
Maveric
Apr 23, 2016 04:58 PM
jaguarVP96
Apr 22, 2016 02:21 AM
Jul 19, 2011 03:26 AM
Mar 13, 2007 12:07 PM
