Crankshaft pulley removal
Old Jul 10, 2022 | 03:49 PM
Kutthroat's Avatar
Default Crankshaft pulley removal
Any suggestions for removing the crankshaft pulley? I tried using a jaw puller but don’t want risk damaging the pulley. Any suggestions or links to a certain tool will be a lot of help.
Old Jul 10, 2022 | 07:45 PM
motorcarman's Avatar
Jaguar answered that question a few decades ago. TSB for you.
File Type: pdf
File Type: pdf
Old Jul 10, 2022 | 08:21 PM
Kutthroat's Avatar
PDF says it’s for 97 xk8 will that same exact tool work with the 02 xjr supercharged crankpulley?
Old Jul 10, 2022 | 08:52 PM
The EARLY V8 pulleys were different.
The later pulleys used the 'split-cone' and a pair of M8 x 1.25 long bolts and a steering wheel puller kit will work fine.
I included the early TSB because you did NOT specify a MY.
Please include Make,Model,Year when posting a question. Jaguar made changes over the years and procedures also change as well.
Old Jul 11, 2022 | 07:40 AM
Robert Laughton's Avatar
When I did my supercharged ;'99, I had to borrow a tool from the dealer. I think the tool for SC was different.
I hope my memory is right here...but the SC damper is 1 piece (both pulleys are one), so a tool with long reach is needed.
Rob
HeWhoDaresRoyV2
May 15, 2021 02:15 AM
XK for life
Jul 5, 2018 04:33 AM
FrickenJag
Feb 20, 2018 12:25 PM
trucknetjack
May 1, 2015 03:40 AM
