Door remote inconsistent
Old May 20, 2017 | 05:40 PM
Alexc122's Avatar
Default Door remote inconsistent
I just purchased a 2002 XJ8 VP. The remote key requires several times of pushing the unlock button before the doors unlock. Is there anything I can do to resolve this?
Old May 20, 2017 | 05:53 PM
Highhorse's Avatar
Take the remote apart just like replacing the batteries, pull out the board, then take a bit of rubbing alcohol on towel to lightly clean them. You'll probably want to wipe the rubber cover inside to remove any residue. Put it back together and give it a go, ...if the batteries are old, now's a good time to replace them.
Old May 22, 2017 | 10:17 AM
bdboyle's Avatar
Along with Highhorse's description in the previous message...I'll toot my own horn (so to speak...) with the following IF the cleaning doesn't work:
https://www.jaguarforums.com/forum/x...ir-kit-177521/
One point to make: be careful to NOT press the buttons when taking the remote apart. You can screw up the programming/linkage to the car. You need (if it's just the batteries) 2x of type 2016 (not a single 2032 coin type) coin batteries for each; watch the polarity when replacing.
Digital Will
Feb 21, 2026 05:58 PM
JimC64
Sep 22, 2025 02:52 PM
rickead2000
Nov 28, 2018 12:42 PM
CyJag
38
Apr 23, 2017 10:58 PM
powerlord
Oct 21, 2016 07:14 AM
