Door speakee size
Old Feb 22, 2019 | 06:56 AM
Clayauto's Avatar
Default Door speakee size
Hey guys, i ordered new door speakers for the front doors, their website stated they were 5.25. I later saw somewhere on our forum they were 6.5? Will 5 25 speakers work. I just hate to pull the door panels if they are the wrong size. Thanks
2002 xj sport basic audio system
Old Feb 22, 2019 | 08:42 AM
M. Stojanovic's Avatar
The outer (maximum) diameter of the Jag door speaker housing is 6.5 in. but the diameter of the speaker diaphragm is 5.25 in. so it depends which of the two diameters the seller used to state the diameter of the speakers he was selling. Usually, the speakers with the diaphragm diameter of 5.25 in. are called "6.5 in." because the speaker housing has this diameter so you might get speakers that are considerably smaller than the original ones (but you may be lucky). Any detailed specs on the website showing the dimensions of the speakers, mounting hole spacing etc.? The mounting hole spacing of the Jag door speakers is 6.20 in. between two opposite holes.
Old Feb 22, 2019 | 09:04 AM
Clayauto's Avatar
ill check, thank you for your help
Old Feb 22, 2019 | 10:39 AM
King Charles's Avatar
I run Rockford Fosgate P165 6.5 2-ways in mine, they're excellent.
Old Feb 22, 2019 | 07:26 PM
grandell's Avatar
6.5" is the correct size, and definitely preferable to 5.25"
Old Feb 22, 2019 | 08:43 PM
It looks like you will get speakers that are smaller than the mounting hole in the doors. The speaker dimensions guide below shows where the speaker diameter is measured so, for the Jag door speakers, you need 6.5 in. speakers.
richarddavison
Jun 5, 2018 06:48 PM
Karl V
Feb 11, 2018 01:55 PM
Craig Schmidt
Oct 26, 2011 05:54 PM
xtype owner
Sep 24, 2010 06:10 PM
85_305
Feb 5, 2010 04:15 PM
