driver side window
Old Jan 25, 2010 | 12:36 AM
bert_vdp's Avatar
Default driver side window
So here is my rant:
I was driving down to university, and I was drivin' with the windows down. I put the windows up and go to class. I come back and all the windows except for the drivers side work. I press the button and i hear the clicking of the motor wanting to work but for some reason the window doesn't budge. I don't know what it could be and was looking for some insight to this problem.
Old Feb 8, 2010 | 05:51 PM
lowriderdog37's Avatar
Has anybody else experienced this? As of today, I am having the same problem.
Old Feb 9, 2010 | 11:41 AM
test point's Avatar
With noise from the motor that probably eliminates electrical problems. Many posts on loose / bent components in the window regulator. Next step is removing the door panel.
Old Feb 9, 2010 | 04:37 PM
Thanks, It's stuck closed...thank goodness. I'll get to it no later than this weekend.
Old Feb 9, 2010 | 04:49 PM
Actually, in a search, you (test point) said to unplug the ground on the battery and let it sit for 10 min, touch it to the positive and hook it back up.
It worked like a charm. The engine was pretty angry after the restart, but it righted itself after a minute.
Thanks for the great info!
Old Feb 9, 2010 | 07:46 PM
test point's Avatar
Another one of my forgotten flashes of adequacy!
Old Feb 11, 2010 | 09:17 PM
bert_vdp's Avatar
i just tried that out. it works perfectly now. thanks guys. i probably would have taken it to a shop if it weren't for you guys.
Old Feb 16, 2010 | 09:21 AM
johnleavitt's Avatar
Worked for me too...
Old Feb 18, 2010 | 08:09 PM
flightcommander's Avatar
Originally Posted by bert_vdp
so here is my rant:
I was driving down to university, and i was drivin' with the windows down. I put the windows up and go to class. I come back and all the windows except for the drivers side work. I press the button and i hear the clicking of the motor wanting to work but for some reason the window doesn't budge. I don't know what it could be and was looking for some insight to this problem.
take a 10 millimeter wrench and disconnect negative battery post in the trunk of the vehicle and wait for 5 minutes---the computer will rest the drivers window after you reconnect the battery and start the car. Good luck. Flightcommander
99xk8guy
Sep 29, 2025 10:51 PM
02jagstype
23
Oct 23, 2022 07:03 PM
kevinl
Oct 31, 2019 06:15 PM
mbergen
Oct 23, 2019 10:26 PM
avern1
Sep 8, 2015 06:25 PM
