Drivers Door "Stopper Failed"
Old Oct 19, 2016 | 05:32 PM
omgimali's Avatar
Question Drivers Door "Stopper Failed"
My 2001 XJ8 Drivers Door just doesn't hold open when you open it at all, it just closes back when you open the door.
Is something failed?
Old Oct 19, 2016 | 06:32 PM
Mark SF's Avatar
Mine makes an awful cracking noise. I suspect the next step is not working at all, like yours.
Old Oct 19, 2016 | 07:48 PM
nilanium's Avatar
On mine, the anchors for the door side of the keeper stripped out and cracked the whole assembly, as well as slightly mangling the sheet metal area around the keeper, so it was just completely loose. A few fender washers and a good assembly from the junkyard, a couple hours fiddling with the tight space there, and it was good as new.
My door is a few fender washers heavier from the fender washers that fell into the inaccessible space between layers of sheet metal at the bottom, so keep that, or a magnet, in mind when doing this.
Looks like the jag name for it is the door check, part GMD1983AB
Old Oct 19, 2016 | 08:10 PM
Samilcar's Avatar
https://www.jaguarforums.com/forum/x...art-how-36075/
The check arm has pulled away from the metal of the door. I ended up just welding in new metal since I already had the door off for other body work, otherwise the metal washer fix appears to work fine.
Old Oct 19, 2016 | 08:32 PM
omgimali's Avatar
When I open the door all the way it makes a crick noise
Old Oct 19, 2016 | 08:33 PM
omgimali's Avatar
Smile
Thank You!
Old Oct 19, 2016 | 08:34 PM
omgimali's Avatar
Talking
I hope something of mine is easier than that. I wished it was just a gas strut haha.
Old Oct 19, 2016 | 08:37 PM
Addicted2boost's Avatar
I think it's Coventry West that sells a nice, rectangular, thick door check repair piece that's well worth the investiment. I put one on my 98' and I bought one for the wife's 00'.
Old Oct 20, 2016 | 09:18 AM
motorcarman's Avatar
The time to repair is when it STARTS making a pop-pop noise.
When the check arm 'goes-silent', you have waited too long.
bob
Old Oct 20, 2016 | 09:54 AM
Jhartz's Avatar
Take it apart first: you need to know whether you need a new check stop or can use heavy washers or a special spacer (all available on-line) to fix the problem. I bought the spacer, took the check stop off to discover that the check stop had broken at the top bolt hole. Waited another week until Gaudin could mail the new stop.
Either way, an easy fix if you remove the door card. Many good threads on each part of the fix.
If it is creaking and/or popping, it is about to fail (mine lasted two years once the noise started), but as Bob noted above, once it quiets down, it is done.
Old Oct 20, 2016 | 01:18 PM
Mark SF's Avatar
Thanks for all the info. I'm going to take mine apart soon!
Old Oct 20, 2016 | 07:31 PM
omgimali's Avatar
Sound good guys, I will be doing this. thank you!
