Early Timing Chain Guides
Old Dec 27, 2024 | 03:42 PM
Doug Dooren's Avatar
Default Early Timing Chain Guides
Does anyone know a source for OEM or OEM spec guides NCA2025AB for the earlier roller chains (1st pic) versus the later silent running chains (2nd pic)? I've ordered from autohausAZ and FCPEuro as they picture the correct part on their websites, but what I get are guides for the later chains. The OEM part from Jag is $125 each (special order from SNG ) which I'd like to avoid. Thanks.
Old Dec 27, 2024 | 04:27 PM
User 42324's Avatar
https://parts.jaguarlandroverclassic...ner-blade.html
Old Dec 27, 2024 | 04:55 PM
motorcarman's Avatar
Ford/Lincoln 3.9 liter guides for the early engines (2000MY) are the same.
I searched the websites until I found them and bought several sets because I anticipated the NLA status of these parts someday.
https://www.autohausaz.com/catalog?k...age=1&sortby=r
Old Dec 27, 2024 | 05:29 PM
That link is the first supplier I tried - correct part pictured but no longer supplied - Eurospare is apparently only supplying the later guides. I'll try the Ford route. Thanks.
Old Dec 27, 2024 | 06:00 PM
Does this look like the correct Ford part? Thanks again.
Old Dec 27, 2024 | 07:46 PM
Try https://www.partsgeek.com/
https://www.partsgeek.com/catalog/20...uide_rail.html
Old Dec 28, 2024 | 05:31 AM
Saw that - they picture the correct Eurospare part but experience tells me they'll supply the later guides. Will see if I can get through to a human being to confirm (wish me luck). Thanks again.
Old Dec 28, 2024 | 07:57 AM
I ended up ordering the above PN from a Ford dealer - $40 each. Very few of these OEM guides left in stock in the US - that "NLA status of these parts someday" is here. Thanks again.
Hyrum Lindquist
Sep 17, 2020 07:54 PM
IXLLER8
Jun 25, 2018 05:15 PM
sshowell99
Dec 19, 2013 12:49 PM
TN8Shooter
Sep 30, 2012 09:16 PM
