eBay Transmission Dipstick
Old Jan 15, 2013 | 12:37 AM
BMC Nut's Avatar
Default eBay Transmission Dipstick
In case anyone was wondering, kinda as am I, the 17.98 eBay dipstick is too long for the tube, however it stops I have taken two pictures with the pan off on the lift to show how far it does go down. The first picture is from the rear of the car facing forward you can see the filter hanging down, my phone is essentially resting along side the valve body.
The second picture is a similar image however from the front of the car to the back. You can see the low temperature indicator on the stick.
Does anyone have a rough idea, is this where its supposed to be or does it have to drop down farther seems to me based of other vehicles as if it may be about right considering its supposed to take about 4 quarts.
Attached Thumbnails eBay Transmission Dipstick-0cd75c52-4102-45e2-9e10-11a1772e0810-1136-0000007be6c5699d.jpg   eBay Transmission Dipstick-4499dc2f-9765-49c5-9cb6-183db5161c85-1136-0000007bda6fcf46.jpg
Old Jan 15, 2013 | 03:03 AM
Maxville's Avatar
The important thing on the dipstick for the MB 722 tranny is the indication area. The lengh of the rest is not important.
Put the dipstick in the tube and push it to the bottom of the oil pan.
To bring the oil stand in the correct level, you have to warm up the transmission ( about 80°C ) then push it into drive and hold the brake, now you can see the real level of oil.
Hope it helps.
Old Jan 15, 2013 | 09:41 AM
BMC Nut's Avatar
This dipstick will not go into the pan any farther than it currently is. I also have the one for the Chrysler transmissions in my shop as well was going to try that one out tonight. The bottom of the pan seems wrong, there has never been a car in my history of working on cars (about 30 years) that it checks from the very bottom of the pan. I have read that on here and that seems to be the accepted means and no one is having problems so I guess it is just another great case of engineers being too smart for their own good.
According to the workshop manual it says to cycle the trans from park to drive, drive to reverse, and lastly reverse to park to check the fluid.
Old Jan 15, 2013 | 02:24 PM
Maxville's Avatar
Ok, i only can tell from my Transmission change in the last weeks on our W210 E55.
I built the dipstick by myself and it works well but its also way too long, if you want i could show you a picture.
The "Meister" of the MB workshop, told me to check the level in drive so the Transmission still have enough oil under all conditons.
Regards from Munich
Old Jan 15, 2013 | 04:08 PM
BMC Nut's Avatar
Yah a picture would be fantastic I'm trying to compare. I also wonder why Jaguar doesn't just make this tool available for sale since it's beyond tool stage at this point and is for maintanence.
I appreciate the info from Deutschland.
Old Jan 15, 2013 | 06:28 PM
aardvark64's Avatar
There are some pretty cheap ones on fleaBay at the moment: £4 (call it €5). So probably not enough for Jaguar to be interested in selling them?
Best wishes, Colin
Old Jan 16, 2013 | 12:26 AM
jimlombardi's Avatar
Here is some information on the XJR transmission Dipstick - Mercedes Benz part numbers for Dipstick and Locking Pin Plug for Dipstick Filler Tube:
https://www.dropbox.com/s/c5n64pilkf...20Dipstick.jpg
Click on image after the dropbox webpage comes up to get a better view.
Jim Lombardi
Old Jan 16, 2013 | 01:54 AM
avos's Avatar
The dipstick shouldn't go any further (certainly not to the bottom of the pan!), and by the looks of if you have the right dipstick. You can see a thicker ring (squarish actually) on the upper side of the black plastic where it will stop in the box to keep it at the right level.
The dispstick in aardvark64 link doesn't seem right to me.
Here is how it should look:
Mercedes Benz 722.6 Transmission Fluid Dipstick Tool 1231 | eBay
Old Jan 16, 2013 | 05:20 AM
Sean B's Avatar
Yes they do to service personnel. From their tool supplier SPX.
Item #307-379
SPX Catalog - DIPSTICK DIPSTICK 307-379
The Benz supplied tools works the same, I just cut it down to 80cm so a bit is left out of the tube, I'm Jaguar specific and don't work on Benz cars so the extra is useless to me. I think the Benz tool is easier to get hold of too, as Avos posted one on ebay.
Old Jan 16, 2013 | 02:03 PM
BMC Nut's Avatar
Yah that square part is what made it stop I know because I ground it off to check now it goes to the bottom of the pan. Almost every person on here said its supposed to go to the bottom of the pan. It took about 5 liters total approximately and seems to be working well. I may order the actual Jaguar one from the link above and check it with that.
Also may purchase another one of the Benz ones with an intact square stop. So many varying opinions and only one thing in the workshop manual which is check with the Jaguar dipstick.
Old Jan 16, 2013 | 02:11 PM
BMC Nut's Avatar
Item #307-379
Damn I can't order it. Doesn't show US shipping.
Old Jan 16, 2013 | 02:30 PM
Sean B's Avatar
The USA side of things...
https://jaguar.spx.com/
https://jaguar.spx.com/Detail/403/30...n_Dipstick?c=2
Never easy with Jaguar!
Old Jan 16, 2013 | 04:10 PM
BMC Nut's Avatar
Thanks Sean damn may wait a while to buy the $60 dipstick hahaha.
Old Jan 16, 2013 | 05:29 PM
Maxville's Avatar
First the Dates/Measurements of the original MB dipstick ( MB part number W140589152100, may you ask for the price directly at MB here in Germany its around 25,-€ )
The lengh overall is 122cm and without grip 116cm the diameter is about 6mm The following marks are from the bottom of the dipstick! 1 mark 11mm 2 mark 22mm 3 mark 54mm 4 mark 64mm * The area between mark 1-2 is for the transmission temperatur around 40°C and the area between mark 3-4 for the temperatur around 80°C
Tomorrow i show you a picture of my selfmade dipstick, really easy to built.
Old Jan 16, 2013 | 05:55 PM
danielsand's Avatar
Originally Posted by sandy85
everytime i read this threads title i think you talk about lipstick, weird.
but when we are on the topic, anybody know about where to get matching British racing green lipstick?
Ahhh,.....lipstick-dipstick,.....wait a minute! There is some relation there, but I forgot. Anyway,.....asking bunch of guys where to buy a lipstick!!? You yourself said in one of your previous posts that "one should not be posting drunk". Breaking your own rules now, or what?
Also,....seems like British Racing Green is growing on you, huh? Otherwise you would be looking for a gold lipstick!
Old Jan 16, 2013 | 10:45 PM
avos's Avatar
Had borrowed the Jaguar tool many years ago, but that one was a pain to use as it wasn't sturdy enough to push down the tube. Maybe it's improved now, but I wouldn’t try it even, just go for the sturdy ones as shown in the eBay link in post #8 (and don't modify!).
Old Jan 16, 2013 | 10:58 PM
Tirefriar's Avatar
Will the dipstick you are recommending give me precise measurement and can it be just installed and left in the tube? Thanx.
Old Jan 16, 2013 | 11:28 PM
avos's Avatar
This tool (exactly as pictured) is specifically for this type of gearbox, and it’s not intended to stay in the tube, it is what the MB dealers use.
Just as important is to follow the right filling procedure, so with running engine go thru the gears (so all channels will be filled with oil), and also measure (again with running engine) the oil at 80c (so the upper marks of the lipstick).
The dealer tool will only show the gearbox temp in R or D), and if you don’t have that, you could use an IR Heat gun, but the oil pan will probably read about 10c cooler then the oil inside, so something to take into consideration.
Old Jan 17, 2013 | 03:46 PM
I tried to order the tool for the quick-connectors from SPX - tool was $15 plus $19.39 shipping/handling charge to this tiny U shaped tool.
I can only imagine what the shipping/handling charge will be for a $60 dipstick.
Here is a mercedes benz dipstick on Ebay being offered at $25 and free shipping from Poland to USA - says professional:
https://www.dropbox.com/s/oownt1u3w9...20Dipstick.jpg
Click on image after the dropbox webpage open to see a really large image of the dipstick.
Jim Lombardi
Last edited by jimlombardi; Jan 17, 2013 at 05:35 PM. Reason: was tool $19.39 plus $15,correction is tool $15 plus $19.39
Old Jan 18, 2013 | 12:09 PM
Maxville's Avatar
This is my dipstick.
Attached Thumbnails eBay Transmission Dipstick-%D6lstab1.jpg   eBay Transmission Dipstick-%D6lstab2.jpg   eBay Transmission Dipstick-%D6lstab3.jpg
