Electrical system shuts down.
Old Jan 5, 2014 | 05:22 PM
donv77's Avatar
Default Electrical system shuts down.
My 2003 XJ8 has a n electrical/electronic intermittent problem.
On occasion, when the key is inserted into the ignition switch all power is lost and it will not start. After sitting for a period, an hour to several, when the key is inserted the power is back and it will start. Also just recently the cruise control works intermitently as well and the "engine warning lite" comes on. It goes off when the cruise is turned off.
Can anyone shed any light on these issues?
Thx,
Don
Old Jan 5, 2014 | 05:50 PM
Don, I've moved your post from the general tech section to the X308 section (specific to your model year) which will get your question more visibility and better response.
regards
Old Jan 5, 2014 | 06:45 PM
motorcarman's Avatar
I would check the battery posts or the MEGA-FUSE in the boot for a good connection as a starting point.
bob gauff
Old Jan 5, 2014 | 07:06 PM
donv77's Avatar
Hi
Battery posts are clean and tight. Since this only happens when inserting the key in the ignition I'm thinking the switch. The peculiar thing is it seems to happen when the key is not fully turned to start. This has only happened twice and all lights, radio everything electrical shuts down.
Where is the Mega Fuse in the boot?
Thx
Old Jan 5, 2014 | 08:30 PM
Follow the POSITIVE battery cable to the little plastic square on the front of the spare wheel/tire well.
There is a fuse assy that could become corroded and have a faulty connection.
Not likely but possible.
bob gauff
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
1100me
Sep 7, 2015 06:26 AM
mcdutch
Sep 4, 2015 03:38 AM
