Engine cut out and will not re-start
Old Jul 3, 2012 | 10:39 AM
lofty's Avatar
Default Engine cut out and will not re-start
Hi All,
My 2000 XJ8 is playing up again.
Driving home from work, the engine just cut out. Tried to restart with no joy. I left it for about half an hour and tried again. It did then start but it was ticking over on very low revs and when I pressed the accelerator no additional revs came in. Had the car towed home (car was only 0.5 mile from home and 30 miles to a garage) and I've got no way of pulling any codes.
I have no technical ability or understanding of engines or electrics unfortunately, but if I could get some idea of what the problem might be (and how much it costs) I can then make a choice on having her fixed or consider if it is time to let the old beast go to the big garage in the sky. Does this sound like a fuel pump issue?
Many thanks in advance for any help.
Lofty
Old Jul 4, 2012 | 10:13 PM
avt007's Avatar
It kinda sounds like a fuel pump. When it died, did it just switch off abruptly, or did it stumble a bit first?
Old Jul 5, 2012 | 03:51 AM
lofty's Avatar
Hi Rob,
Many thanks, I lost power for a couple of hundred yards, then it just cut out. I think I'm going to have to get the code(s) pulled, you never know it might just be a relay or something simple.
I noticed that a few days later the battery was flat, is a low battery something that can put a gremlin in the works and send me in the wrong direction.
The battery is only about 18months old, do they go that quickly?
dsnyder586
Dec 29, 2024 07:39 PM
philwarner
Oct 4, 2024 01:37 PM
Wolfy
May 28, 2024 08:06 AM
cissdm
May 3, 2016 06:02 AM
uncheel
Sep 5, 2015 01:34 PM
