Engine failsafe mode but car working fine
Old Nov 17, 2024 | 05:32 PM
Silverjag0's Avatar
Default Engine failsafe mode but car working fine
Today I saw engine failsafe mode on the dash but the car working fine and no obd codes
I turned off the car and started again nothing wrong with it but still showing fail safe any idea?
Old Nov 17, 2024 | 05:57 PM
motorcarman's Avatar
You will most likely have a DTC on one of the modules on the CAN bus but might be a U or C code?
Old Nov 17, 2024 | 06:33 PM
Silverjag0's Avatar
Disconnected the battery for while and reconnect again
I got ABS trac not available and failsafe
So I think it's related to C code but my obd can't read brake system problems I'm not sure if abs failure will throw failsafe mode , should I look further or just fix the abs ?
Old Nov 18, 2024 | 06:27 AM
jrb53's Avatar
Default Brake pedal
check you brake pedal switch see if you have cruise control if not it most likely switch is bad
Old Nov 18, 2024 | 07:05 AM
Silverjag0's Avatar
You're right no cruise control
And the rear right light is on by its own the brake switch is bad . Thanks
Old Nov 18, 2024 | 12:07 PM
Addicted2boost's Avatar
I’ve seen bad SLCM’s keep a tail light on at all times before and more than once. I wouldn’t blindly throw parts at a car to fix it unless you already have another brake switch and/or SLCM in your parts stash.
Old Nov 18, 2024 | 12:47 PM
Silverjag0's Avatar
I will use advanced autel obd reader to get access to security system and brake
Old Nov 19, 2024 | 11:50 AM
vincent661983's Avatar
check your ABS module and throttle body
captainobvious1
May 14, 2024 08:33 AM
KWinn
Apr 13, 2024 04:25 PM
asjdhsajhdfj
Jun 28, 2023 06:49 PM
stevehill
Oct 26, 2012 10:01 PM
djsomebody
Jul 18, 2011 08:16 PM
