Engine Light
Old Jun 26, 2009 | 12:51 PM
portlandjag's Avatar
Default Engine Light
Is there a way to reset this to off? I have fixed the problem and tried disconnecting the negative battery terminal (as well as the positive) with no result. I also completely disconnected the ECU and still no reset. It has been on for about 2 days now. The problem was a dirty MAF sensor which I cleaned and the car runs perfectly now.
Old Jun 26, 2009 | 01:41 PM
H20boy's Avatar
Gonna need a code reader that has the ability to clear it. If you catch your jag service advisor in a good mood and at a slow time, he may do it at no charge. Call ahead, explain the new repair you did to your MAF sensor, and he may recommend a time to come by. It couldn't hurt.
Old Jun 26, 2009 | 04:51 PM
johnleavitt's Avatar
you can get a code reader with a reset button for less that 70 bucks now...handy to have.
toronadomike
Jan 22, 2026 10:13 PM
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
OkieTim
Sep 2, 2015 12:48 PM
TC Johnson
Sep 2, 2015 09:30 AM
