Engine management code and no bolt on air hose!.
Old Apr 22, 2019 | 11:18 PM
mat32essex's Avatar
Default Engine management code and no bolt on air hose!.
I have noticed there is a bolt missing on one of the air inlets!. The picture is below its loose and the seal does not meet properly would this cause any issues ?. If not I won't worry about it if it may cause problems does anyone know what size bolt this would be ?. Also, I am getting the error code P1646 manufacturer code on a Maxi Scan diagnostic tool. I wondered if anyone knows what this code means ?.
Air inlet!
Old Apr 23, 2019 | 02:47 AM
JagV8's Avatar
It's not ideal - I'd fit the bolt
Old Apr 23, 2019 | 11:17 AM
Jhartz's Avatar
Seriously? Pull the bolt on the other side and go visit your parts store.
You will likely have a vacuum/air leak without the gasket fitted correctly and snugged down with a new bolt. While you are there, clean the throttle bore and plate (use the correct throttle cleaner -- same parts store where you buy the bolt).
While there, price a new upstream oxygen sensor (P1646 -- learn to use Google search tools!). Reset codes. Quite likely, however, cleaning and tightening the cover to the throttle body may solve that issue. Let us know.
Old Apr 23, 2019 | 09:03 PM
Don B's Avatar
Mat,
Don't mind Jim. He forgets that common sense escapes all of us at times!
I'm going to guess the screw you need is M6-1.0 flange head, 25 to 30 millimeters long.
When one of the screws broke through the plastic "ear" on the intake pipe of our 2003 where you are missing a screw, lean codes were triggered (P0171 & P0174).
Regarding your P1646 code, here are the definition and possible causes from the DTC Summaries guide:
Please let us know what you learn at the hardware store.
Cheers,
Don
Joel Moross
XJ40 ( XJ81 )
Jun 9, 2017 07:21 PM
DavidT
Dec 27, 2016 07:08 AM
Docuzzie
Apr 23, 2015 03:31 PM
pegasus3710
May 19, 2011 03:57 AM
Delta66
Aug 27, 2009 09:34 AM
