Exhaust System 2.5"
Old Jun 23, 2012 | 01:37 PM
fitnessrx's Avatar
Default Exhaust System 2.5"
Hi!
I´m gonna build a new exhaust system 2.5" stainless steel all the way from the cats. Keeping 4 silencers removing the ones in the middle (second pair), that will be removed and not replaced with new ones. Can Someone tell me how many meters straight pipes I will need and how many bent pipes I will need and in what degrees.
I´m not into fixing with cars so its not gonna be me who will do the fitting its going to be my cousin and I want to order the pipes before I give him the car. Otherwise I will lose it for a couple of weeks...
Thanks!!
Old Jun 23, 2012 | 02:58 PM
WaterDragon's Avatar
You will save lots of money on cuss words if you go 2 1/4" instead of 2 1/2"over the rear axle.
Ask XJR-0220 about this, that was a difficult fitting job I hear.
Old Jun 23, 2012 | 09:29 PM
XJR-0220's Avatar
Honestly I would go with 2 1/4 being that 2.5 is very hard to get up and over the rear axles and on a side note I would say 2 1/4 is pretty much optimum sized
Old Oct 9, 2012 | 03:23 AM
fitnessrx's Avatar
Well now its done... I did sidepipes... Pictures and videos will come in a couple of days
Old Oct 10, 2012 | 08:18 AM
sbreeden's Avatar
Side pipes will be an interesting look, can wait to see pictures.
Old Oct 12, 2012 | 07:41 AM
fitnessrx's Avatar
Well now it actually sounds like a V8..
Attached Thumbnails Exhaust System 2.5"-imag0168.jpg   Exhaust System 2.5"-imag0167.jpg   Exhaust System 2.5"-imag0166.jpg   Exhaust System 2.5"-imag0165.jpg
Old Oct 12, 2012 | 07:46 AM
fitnessrx's Avatar
wtf cant upload video
Old Oct 12, 2012 | 09:31 AM
sbreeden's Avatar
Where did you get the flex pipes from?
In order for side pipes to look good, you need a side skirt, which the XJ don't have.
I know thats not the finish look, you going to need some serious imagination to get that to look good.
Old Oct 12, 2012 | 09:37 AM
fitnessrx's Avatar
Who cares about looks its the power and sound I want. Dosent look worse than it did before anyway
The flexpipes are nonames. But will probably put on 2 straight mufflers at the end on both side. Its almost 2 much..
Old Oct 12, 2012 | 09:49 AM
dsnyder586's Avatar
Gasp! Blasphemy!
Seriously though, interesting idea- I would be interested to see if you get any hp gains.
Old Oct 12, 2012 | 10:16 AM
Would it work better to have an x pipe instead of an h pipe?
Old Oct 12, 2012 | 11:42 AM
Sean B's Avatar
youtube works well...
Old Oct 12, 2012 | 03:31 PM
sbreeden's Avatar
I wasn't busting down your XJ with the exhaust setup, I'm not that type of member.
Differently need the X-pipe to see any type of gain. The straights might just be noise HP gain, most likely you losing HP with a setup without a X-pipe.
There are a lot of recent post relating to where to install the X-pipe within exhaust setup.
Old Oct 12, 2012 | 04:54 PM
fitnessrx's Avatar
Originally Posted by dsnyder586
Gasp! Blasphemy!
I would think so. I´m flying now. Did the upper pulley at the same time thou
Old Oct 12, 2012 | 04:57 PM
fitnessrx's Avatar
Read alot about x-pipe... if you aint putting it exxaaactly where it should be you lose HP. And why risk it.
silkcat
Jan 18, 2025 04:29 AM
Daim
Nov 28, 2016 09:28 AM
Aus V8S
Nov 13, 2015 11:01 AM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
XJ8JR
Sep 11, 2015 12:31 AM
