Fog Lights Staying On
Old Jan 30, 2023 | 07:27 AM
gatorVDP's Avatar
Default Fog Lights Staying On
2001 VDP
This one has been sitting for a very long time, and the battery died. The battery was apparently dead so long that it wouldn’t charge, so I replaced it with a shiny new one thanks to Interstate Battery’s warranty. Now the fog lights stay on all the time with no other lights on. Tried turning the headlights on and off. Tried cycling through the fog lights on and off. Drove the car around a bit giving it time to adapt to its new found power. Fog lights still on. They are even on with the car shut off, key out of the ignition and all of the doors locked. The only way to turn them off is to disconnect the battery.
I’m hoping one of you has had a similar problem and can point me in the right direction to fix this peculiar problem. Many thanks.
Old Jan 30, 2023 | 08:07 AM
Hooli's Avatar
I'd assume they are switched by a relay & that's faulty.
Old Jan 30, 2023 | 10:04 AM
RandyS's Avatar
There are a couple of places to check. You can check both and they are
in the engine compartment fuse box. First is the fuse in
F17 15A for both
front fog lights and second is
relay number 2 which is the front fog relay.
I would suspect the relay has gone south.
Old Feb 1, 2023 | 06:55 AM
gatorVDP's Avatar
Default Many, Many Thanks
Thanks guys for your replies. Admittedly, I'm feeling quite silly for not checking the relay. I'm sure that's it. Work load is limiting my tinkering on this girl to weekends, so I'll be checking it Saturday. You guys are great!
Old Feb 12, 2023 | 12:04 PM
gatorVDP's Avatar
After unplugging the relay a couple of times, the fogs light finally went off. They now switch on and off like they’re supposed to. Thank you again for your suggestions.
Old Feb 13, 2023 | 08:27 AM
RandyS's Avatar
As these cars age, electrical junctions can corrode and relays can
get tired. There is no magic to be deployed in these cases. Forum
members just need to be aware that this can happen and be prepared
to chase the current till the problem is discovered.
chiefshb
Feb 20, 2020 12:08 AM
Wv xjs
Aug 6, 2015 01:05 AM
Xx_Four_Stroke_xX
Sep 12, 2010 08:01 PM
hlgeorge
May 2, 2008 07:50 PM
