Found My Coolant Leak
Old Sep 17, 2016 | 12:15 PM
4litre's Avatar
Default Found My Coolant Leak
Well the mysterious coolant loss has revealed itself in full force last night. The large hose under the intake manifold on the driver's side let go and keeps coolant out of the engine. Has anyone replaced this hose without removing the SC and intake manifold?
Old Sep 17, 2016 | 02:00 PM
Highhorse's Avatar
You'll have to remove it and replace both lines, its not hard, don't be intimidated. Just do a search "supercharger coolant lines", you'll come across a number of threads...here's one that'll probably answer what you want. Gopi went into some detail, so I started you on page 2...https://www.jaguarforums.com/forum/x...-160413/page2/
I also wrapped mine with foil when I did mine the first of the year. Pay attention to post #34 where he shows the hose size difference and my reply in #35.
Old Sep 17, 2016 | 02:19 PM
4litre's Avatar
OK I'll research this and get it done...thanks a million!!! 😁
Old Sep 17, 2016 | 04:01 PM
motorcarman's Avatar
Without a MAKE, MODEL, YEAR we are guessing that this is a V8????
If you are talking about a 1995,96,97 X300 water rail hose, then you are in the wrong forum.
bob
Old Sep 17, 2016 | 04:20 PM
4litre's Avatar
bob
Please trust that I'm in the correct forum. It's a '98 XJR...
Old Sep 17, 2016 | 11:19 PM
Addicted2boost's Avatar
While you have those 2 hoses out, nows the time to replace that 3 way plastic tee on the D/S next to the TB elbow. And drain and fill the S/C oil.
Old Sep 18, 2016 | 07:53 AM
4litre's Avatar
Okay thanks a lot for that
Old Sep 19, 2016 | 12:40 PM
4litre's Avatar
So far, the coolant reservoir and manifold, are off. Bolts loosened for top of SC just finding my way around the engine bay. Snapped line to radiator DOH! Should've disconnected it from the start...sigh...had to stop due to rise in temperature outside. Becoming a bit much to work in...a little ways to go but it's getting there 😀 think I will just remove SC and throttle body to get the hoses out.
Old Sep 19, 2016 | 01:09 PM
4litre's Avatar
Old Sep 19, 2016 | 01:17 PM
4litre's Avatar
Tomorrow the belt and throttle body will come off as well as the SC. I'll go to the auto parts store to match the diameter of the hoses, cut then bow them so there will be no kinks. At least that's the plan 😀
Old Sep 19, 2016 | 08:22 PM
Highhorse's Avatar
You'll want to check your pulleys and tensioners and if you need any new its real easy to just replace the bearing...https://www.amazon.com/gp/product/B0...F8&psc=1...and much cheaper. I used a socket and a persuader to knock it out and back in, goes smooth and quick. I believe that bearing works on all the pulleys? Hopefully someone can verify that who has done them all?
I have a new supercharger belt available if you need one, just pm me.
Old Sep 19, 2016 | 10:12 PM
4litre's Avatar
Wow thank you so much bro!
Old Sep 20, 2016 | 04:25 PM
4litre's Avatar
Removed SC belt (DUH) found it's tensioner...throttlebody off...looking at EGR valve and elbow. Trying to plan the attack in my head...I can visualize sweet victory soon!
Old Sep 21, 2016 | 12:06 PM
4litre's Avatar
Decided not to pull EGR but disconnect at the elbow. There is something I need help with. There is a hard line on the passenger side of the elbow and it doesn't have the connection to push out like the others. Anyone have suggestions?
Old Sep 21, 2016 | 12:11 PM
4litre's Avatar
Default The line...
Not sure how to remove without destroying...
Old Sep 21, 2016 | 03:48 PM
4litre's Avatar
...use fingernail to push o-ring in then gently pull. Jaguar...really? At least I know now so I'm passing it along.
https://www.jaguarforums.com/forum/x...removal-38101/
Old Sep 22, 2016 | 04:11 PM
4litre's Avatar
Default SC and stuff out and the hoses are history!
Going to rest then re-assemble with fresh ingredients to pursue life on the road...
Old Sep 27, 2016 | 08:20 AM
4litre's Avatar
Fully assembled, runs great...aside from the norma connector at water manifold deciding to give up the ghost...sigh. At least I can see it. Thanks everyone who has helped me through this. I've learned a lot about my car
Old Sep 27, 2016 | 09:56 AM
4litre's Avatar
Update:Temporary field patch on norma connector at water manifold...clipped hard line off at snapped connector end, used a cylindrical stereo wire connector with metal inside and pushed into hard line so it sits snugly, cut rubber hose to size, clamped onto end. Metal inside stereo connector keeps hard line from compressing. No leaks. This will keep you going until the new connector arrives...
worrasf
Apr 21, 2021 05:30 AM
Helen Serrano
Oct 2, 2016 04:14 PM
philwarner
Sep 17, 2016 02:46 PM
cadmat
Sep 17, 2016 04:02 AM
Bavery767
Sep 16, 2016 07:54 PM
