found the source of noise from the engine bay,need to identify this part
Old Nov 8, 2014 | 01:58 PM
vincent661983's Avatar
Default found the source of noise from the engine bay,need to identify this part
finally I traced to the source of the noise from the engine bay coming from this part but I am not able to identify what it is exactly
noise is coming from cylinder shape piece between the radiator fan and the engine more off to the right side of the car
it is at around 8 o'clock from the AC bump.
on the top it read "Made in Germany" then PA 66-GH25
thank you
Jim?
Old Nov 8, 2014 | 01:59 PM
found the source of noise from the engine bay,need to identify this part-forumrunner_20141108_145931.png
Old Nov 8, 2014 | 02:44 PM
luc's Avatar
luc
thank you
Jim?
Water pump for the supercharger cooling system
Old Nov 8, 2014 | 04:22 PM
part number ?
Old Nov 8, 2014 | 06:28 PM
avt007's Avatar
JTIS says it's an MNC8260AC.
Be sure to follow the air bleeding process after replacing the pump. If it just sits and cavitates it could overheat and fail again.
Old Nov 10, 2014 | 09:33 AM
so that is the same part as what we call the intercooler pump.
I was thinking to grade upgrade to the Bosch Highflow pump before so I think now I should consider more seriously
I am also aware the Eurotoys sells a ready to plug-in kit but price is a bit too step.of course one day I want to buy the larger intercooler itself
I wonder if I can use the Mustang Corba one and I mind to do some minor midification
Old Nov 11, 2014 | 08:20 AM
so are we all certain that is the intercooler pump because I am going to order it? please
Old Nov 12, 2014 | 04:07 PM
avt007's Avatar
Unplug the pump and see if the noise stops.
Old Nov 12, 2014 | 04:14 PM
I used the mechanic sonar scope to listen and also a long screwdriver to detect the noise and vibration.
100% is coming from that "part" so I just need help to identify if that is the intercooler coolant pump
thank you
Old Nov 13, 2014 | 04:54 AM
avt007's Avatar
I'd like to help but I am away on business and my jag parts list is at home. Try some online parts catalogues.
BrentGardner
29
Dec 16, 2024 12:13 AM
ogorir
Sep 3, 2015 07:34 PM
lee,lee
Aug 31, 2015 04:35 PM
1100me
Aug 28, 2015 09:48 PM
Andrew McVey
16
Aug 27, 2015 07:21 PM
