Front wing change
Old Sep 26, 2016 | 07:24 AM
XJ8Lou's Avatar
Default Front wing change
Hi all,
Just a general plea for a few tips. My driver side front wing on my X308 has fallen victim to rust, I have a replacement and was thinking of changing it myself. Any tips or pointers??
Also on the replacement wing the silver 'pin stripe' running down the side is broken, is that an easy fix??
Cheers!!
Old Sep 26, 2016 | 02:07 PM
Samilcar's Avatar
I did this last year and remember it being a fairly easy "bolt-off, bolt-on" procedure. Can't help you on the pin stripe.
Old Sep 26, 2016 | 03:40 PM
Stu 1986's Avatar
The pin stripe is painted on in the factory, you'd have to get someone really good to repaint it or get some stick on stuff from a motor factors. The front wing is easily removed. There are nuts at the front behind the area of the bumper where the reflector is, behind the wheel arch liner at the rear and the bolts along the top.
carzaddict
Sep 19, 2023 11:09 AM
elindo
Apr 10, 2023 07:27 AM
Jim Goodall
Nov 2, 2020 08:24 AM
Asdrewq
Sep 9, 2016 09:24 AM
SD96XJ6L
Aug 29, 2016 04:32 AM
