Full Load Breather Hose
Old Jun 1, 2016 | 08:56 PM
larney's Avatar
Default Full Load Breather Hose
OK I finally got the FLB hose routed through but I can't get it to clip onto the TB. Any tricks? I can get it on and almost snapped... Just can't seem to get that last little bit. So at this point I walked any so I wouldn't break anything else. I didn't take off a lot of suff. Disconnected several electrical connections. Can see it just can't get the push.... Please help???
Old Jun 1, 2016 | 09:00 PM
harvest14's Avatar
You talking about the part-load breather hose? If so, I had the same dilemma. In the end, I just had to use a little more force than I felt should have been necessary. When I did however, it made a very satisfying "snap" sound and I moved on.
I am hesitant to tell you that though, because I don't want you to break something and feel that my advice was responsible. I'm just telling you my experience. I pushed it very hard, and it snapped onto the throttle body connection.
Old Jun 1, 2016 | 09:15 PM
larney's Avatar
Yes I did mean the PLB. Had to replace both due to not being careful.
Didn't know if there was a trick or something. Part of it I think is the awkward position of trying to push up. So just push a little harder? Don't worry I break crap at my own risk... Without anyone's help. Just push harder is the trick...
Thanks.
Old Jun 1, 2016 | 09:26 PM
plums's Avatar
Lubricant is your friend in this situation.
Is there perhaps an old o-ring that got
left behind when removing the old fitting?
Old Jun 1, 2016 | 09:27 PM
motorcarman's Avatar
Lube the 'O'rings and push it into place. I use rubber grease or silicone spray!!
bob
Old Jun 1, 2016 | 09:34 PM
JTsmks's Avatar
I keep a container of "electrical wire pulling gel" on the shelf for such things, super slippery and water soluble (they're 80% water) and evaporative so after a day or so no residue left over.
Old Jun 3, 2016 | 08:49 PM
larney's Avatar
Thanks to all. Little lube and a lot of pushing and SNAP it's on.
CleverName
US Northwest
Jun 7, 2016 05:33 PM
gwagner
Jun 4, 2016 12:34 PM
rgp
Jun 4, 2016 05:18 AM
Whompert
Jun 2, 2016 01:17 AM
malc4d
Jun 1, 2016 06:02 AM
