Gap in air intake system
Old Apr 8, 2011 | 02:36 PM
cclipse01's Avatar
Default Gap in air intake system
Hi guys. Well I've had my Jag for about 3 years and just decided to do minor work on the car myself. As I was looking at the engine, I noticed a gap in the Air system between the hose and the air box. Am I missing something there? The hose is stiff and doesn't stretch to close the gap. Any info or suggestions appreciated and I Love the site!
Old Apr 8, 2011 | 02:41 PM
cclipse01's Avatar
Here's a pic with an arrow pointing to the area, the gap is greater on the underside of the tube... Thanks again!
Old Apr 8, 2011 | 08:56 PM
Rae's Avatar
Rae
cclipse01: Based on my experience, there's nothing missing. The intake going to the throttle body should have an accordion section just past the tube coming in from the valve cover. If you loosen up the clamp, you should really be able to tighten up this gap. You could remove intake from throttle body, tighten up the gap, and then place back onto the throttle body, being careful not to burger up the gasket. Good Luck, and I too love this site!
Old Apr 9, 2011 | 03:28 PM
SuperSport's Avatar
I've had the same issue, but if you loosen the clamp as mentioned above, you should be able to stretch the hose enough to close that gap. It takes a bit of muscle, but it works.
clubairth1
30
Sep 3, 2025 04:38 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
cissdm
May 3, 2016 06:02 AM
Saturbo
Sep 8, 2015 07:35 PM
1100me
Sep 7, 2015 06:26 AM
