Gearbox problem
Old Jan 25, 2015 | 11:27 AM
Niklas Xeronen's Avatar
Default Gearbox problem
Hi! I have an issue with my gearbox... today when hade the car on idle a couple of minuets, later when I was about to drive it was impossible to get the stick in D.. it was stuck in P. I had tried to hit the breaks a couple of times and to restart the car but the problem remains. What to do?
Old Jan 25, 2015 | 02:57 PM
JagV8's Avatar
First is to give car details.
Old Jan 25, 2015 | 05:24 PM
Fraser Mitchell's Avatar
Assuming you have an XJ (X350) model, (the all aluminium cars), then there is a little solenoid in the gearshift module that is activated by a switch on the brake pedal. So to put the car into gear, one must first press on the brake pedal. So it seems you either have a fault with the module or the brake switch. Do your brake lights work ?
Old Jan 29, 2015 | 06:50 AM
oldmots's Avatar
Pull the top off of the shifter and look down inside. I had the same problem and found a piece of plastic jammed in the track. I removed it and have had no problem since.
Old Feb 2, 2015 | 06:53 AM
Darnit, Im inte the wrong section. I have a 1998 XJR. But I will try the things you guys said anyway they seem to be good hints.
Thanks!!
Old Feb 2, 2015 | 04:09 PM
Don B's Avatar
Niklas,
I have moved your thread from the forum for the X350 to the forum for the X308, which is the Jaguar factory code for 1997-2003 XJs with 8-cylinder engines. Here your questions will be visible to knowledgeable owners of similar cars.
I believe your '98 has a brake pedal/gearshift interlock system, so the first possibilities that come to mind are the neutral switch in the gear selector module or the brake switch connected to the brake pedal assembly. There have been lots of posts on this topic - you can use the Search window at the top of this page to research them, and hopefully other members who have resolved a similar issue will respond.
Cheers,
Don
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
cissdm
May 3, 2016 06:02 AM
jimforrest (uk)
Jan 25, 2016 03:51 AM
pnwrs2000
Sep 3, 2015 11:55 AM
