GMB water pump for XJ8
Old Jan 25, 2011 | 01:44 AM
Dan R's Avatar
Default GMB water pump for XJ8
I have a chance on a good deal for a GMB 125-6030 water pump.
The impeller is black "plastic". Is this as good a unit as the Jag original?
Thanks,
Dan
Old Jan 25, 2011 | 05:05 AM
test point's Avatar
Don't know about that specific pump but the original early pumps that had such a trouble history had black plastic impellers. This isn't a 12 year old NOS is it? The coolant pump is about the only thing on these cars that is reasonably priced. OEM units typically under $70. What is your good deal price?
Old Jan 25, 2011 | 08:51 AM
motorcarman's Avatar
Here is some info to consider when buying a pump with a plastic type impellor.
bob gauff
File Type: pdf
Old Jan 26, 2011 | 08:17 AM
jaginblack's Avatar
I can tell you that my XJ8 pump was replaced by the dealer before I bought it, maybe 5 years ago, and they used a pump with white impellers. You will also find aluminum impeller replacements currently available at a reasonable price.
I have read some posts recommending the metal impeller over all others, and plan to replace mine with metal sometime in the next year, since it now has about 45k miles on it. The original pump failed at about 30k.
Old Jan 26, 2011 | 08:23 AM
JimmyL's Avatar
Talking Water Pump
I went with metal impellors. Despite what any literature says, I feel more comfortable with metal over any kind of stinking plastic.
dsnyder586
Dec 29, 2024 07:39 PM
Wahooesprit
Dec 23, 2019 02:01 PM
CClifton
Mar 19, 2017 02:25 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Jaiello21
Sep 14, 2015 09:42 PM
