headbolt torque specs?
Subscribe
May 1, 2011 | 09:29 AM
replaced bent valves on my dads 98 xj8 4.0 and im ready to put the head back on but cant find the torque specs and pattern for the headbolts anywhere, i searched but no luck.
if someone can help me out id appreciate it.
i found this site with everything else i just cant find the pattern and torque specs
Tmingi chain and tensioner replacement
Reply 0
May 1, 2011 | 09:41 AM
8 4 2 5 9
1-hand tight
2- 15 ft/tq
3- 26 ft/tq
4- 1/4 turn
correct?
Reply 0
May 1, 2011 | 10:13 AM
try looking at page 21 of this pdf, I guess this should help?
Reply 1
May 1, 2011 | 10:18 AM
forgot to mention, im just doing bank B.
Reply 0
May 1, 2011 | 10:22 AM
Quote: try looking at page 21 of this pdf, I guess this should help?
i cant open it since im a noob
Reply 0
May 1, 2011 | 10:45 AM
What Sean's pdf says and what I believe to be correct is your original post is missing a second round of 1/4 turns.
Reply 1
May 1, 2011 | 11:11 AM
yep, after your initial 90, you do another 90. The M8 bolts are torqued to 17-20lb ft.
Reply 1
May 2, 2011 | 09:07 AM
thanks for all the help guys, car is up and running he got it for 800 bucks with 50k miles.
after binging it home i did a compression test and 2 cylinders were 0 on bank b so i took the valve cover off and noticed a failed secondary chain/tensioner which meant bent exhaust valves.
Reply 0
May 2, 2011 | 04:42 PM
What did you do with the bent valves cylinder head? use another head? I've got to ask if you replaced both secondary tensioners or just B bank?
Sounds like a bargain, good man!
Reply 0
Subscribe
Currently Active Users (1)
