Heated Rear Seat Help Please.
Old Aug 21, 2011 | 06:15 PM
Stu 1986's Avatar
Default Heated Rear Seat Help Please.
Hello Chaps,
I in the process of installing an interior from a different XJ8 into my own XJ8 and need some help.
The new interior is from a Daimler/VDP spec car and has the heated rear seat option. I would like to get this working, but an unsure of how it's all connected etc. I have the switch pack for this too, so just need to know where to plug in so to speak.
Thanks Fellas,
Stu.
Old Aug 21, 2011 | 10:16 PM
jimlombardi's Avatar
Hi Stu
You may have to get a rear heater wiring harness that has the multiplug and goes back to the trunk fuse box, if the wiring harness does not exist in your XJ8.
Correction: The rear seat heater fuse is located in the Rear Compartment Fuse Box - Right-hand Heelboard Fuse number 9 with 20 amp fuse not trunk fuse box - number 22, it is a 20 amp fuse.
Here is a PDF file for the Rear Seat Heater Switch R&I:
2001 XJ Rear Console Extension Heater Switches.pdf
Here is a PDF file of the 2001 XJ Electrical Guide:
jzj2001en.pdf
Look at page 25 - Harness wiring diagram - It does not show a separate harness for the rear seat heaters. The rear seat harness may already include the multi-plugs needed for the rear seat heaters.
I also created a PDF file from the JEPC of the rear seats wiring harnesses that are listed:
2001 XJ Rear Seat Harnesses Part Numbers.pdf
Shows part numbers for Harnesses with electric moving rear seats and without electric moving rear seats.
Jim Lombardi
Old Aug 22, 2011 | 12:55 PM
Stu 1986's Avatar
I have looked under the insulation on the rear bench and there is an unused multiplug there who's wires go in the direction of the boot/trunk area. Could this be what you mean? If anyone has any photos of this that'd be great.
Thanks,
Stu
Old Aug 22, 2011 | 03:04 PM
Hi Stu
I do not have any photos, but here is another PDF:
This one shows an illustrations of the rear cushion heater multiplug harness.
XJ8 Rear Seat Track R&I.pdf
Here is another thread that has photos taken by forum member shw57: Removal-Repair of the Rear Seat Heater Switch
https://www.jaguarforums.com/forum/a...ch-removal-pdf
Maybe you can PM him and ask for a photo of the multiplug harness that makes the connection with the rear seat heaters.
Jim Lombardi
Old Aug 22, 2011 | 03:50 PM
Stu 1986's Avatar
Thanks For Your help so far Jim, you're most kind I've been out this evening working on my interior and have been seeing if I can find where it all goes. If I need to make my own harness for this I can do as I have a donor car I can swipe some connectors from and make a loom.
I PM'd shw57 so hopefully we'll hear back soon.
Stu.
Old Aug 22, 2011 | 07:12 PM
watching with interest Stu
Are you doing a write up of any descripition to share your findings? I'm sure it'd be a great addittion to the forum.
Old Aug 23, 2011 | 02:47 AM
Cadillac's Avatar
That's a cool add-on , I do have rear heated seats as well .(had them installed more explicitly lol ) I see no point of why in such high end cars they cheap on these accessories
Old Aug 23, 2011 | 12:53 PM
Stu 1986's Avatar
All I'll say for now is watch this space...
Old Aug 23, 2011 | 04:30 PM
Hi Stu
I just looked the rear heated seat fuse location in our 2001 XJ8 Vehicle Care Handbook. On page 4-18 Roadside emergency service: the fuse location table shows:
The rear seat heater fuse is located in the Rear Compartment Fuse Box - Right-hand Heelboard Fuse number 9 with 20 amp fuse.
Maybe I used the wrong wiring diagram when I found it on the trunk fuse box diagram.
I corrected post number 2.
It can also be found in the 2000 XJ Vehicle Care Handbook PDF file - same page number 4-18:
https://www.jaguarforums.com/forum/a...e-handbook-pdf
Jim Lombardi
Old Aug 26, 2011 | 05:10 PM
Stu 1986's Avatar
Hi Jim, Thanks for your reply about the changes. I have noted everything down but will probably leave this Mod for a couple of months due to time constraints and not having a full picture if you get me. I'm going to try and get a look at an already installed system to give me a better idea of what needs doing.
Thanks Again,
Stu.
dsnyder586
Dec 29, 2024 07:39 PM
JagBrian
Aug 18, 2019 05:07 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Dallas XK8
Sep 3, 2015 12:17 PM
dcvickers
Sep 2, 2015 06:14 PM
