Heater hoses....
Old Jun 15, 2021 | 01:41 PM
cityboy's Avatar
Default Heater hoses....
Friends, I have a 01 VDP with a cooling problem that I thought I had licked but it's back. I replaced the octopus hose (which had been done before in 08) and found the stupid plastic tee in front of it was broken and had leaked for a long time. Got everything back together, not such a bad job, and drove a few miles. As soon as the ignition was shut off I heard a whooshing sound and coolant was coming out from under the intake, the usual, and running down the trans.
I filled it up again to drive home, all went well until I shut it down in my driveway, then whoosh again. Same leak. Now I am thinking I need to lift off the plastic intake to get to the heater hoses under there, and that is OK, I can do it, but I am stumped at why the darn thing does not leak while running. That is a mystery. Anybody else have a similar issue?
Old Jun 15, 2021 | 01:52 PM
motorcarman's Avatar
Sounds like the heater 'feed' and 'return' lines under the intake.
Probably a slight 'split' in the hose and when engine is OFF, heat soak raises the engine temp/pressure?
TreVoRTasmin
Jul 9, 2015 08:07 PM
brgjag
Sep 6, 2014 09:05 PM
coastaljag98
Apr 3, 2013 08:33 AM
macdoesit
Mar 27, 2013 04:09 AM
Brian2000XKR
Jan 11, 2013 05:44 AM
