High level brake light attachment
Old Feb 24, 2015 | 10:01 AM
Freebird's Avatar
Default High level brake light attachment
Hi All
I think my car is missing an attachment bracket for the high level brake light. A previous owner has stuck it to the glass with double sided sticky tape with inevitable results - it's come off.
There are two slots in the light assembly which seem to be there to locate into a bracket stuck to the screen - this is the bit I am missing I think.
eBay has not helped as a source - any ideas?
Glen.
Old Feb 24, 2015 | 10:19 AM
Jhartz's Avatar
I had to use epoxy to 'glue' mine back on, even tho the whole thing was crumbling. You might try a junkyard. There is a specialty junkyard in California that specializes in Jags.
Maybe Guadin or Barrett for a new unit (pricey).
Old Feb 24, 2015 | 10:22 AM
motorcarman's Avatar
The mounting bosses are supplied with the rear windscreen assy.
They are probably NSS (not sold/serviced separately).
Here is an old TSB for detached HMSL.
bob gauff
File Type: pdf
Old Feb 24, 2015 | 11:19 AM
Ronco1's Avatar
Default Thread about high level brake Light
Here ya go Freebird
a pretty good discussion thread on this subject here on this forume
https://www.jaguarforums.com/forum/x...-loose-133786/
D.K
Dec 10, 2023 02:05 AM
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Russ Graber
Feb 23, 2019 11:59 AM
TC Johnson
Sep 2, 2015 09:30 AM
