High pitch whine
Old Apr 7, 2013 | 10:38 PM
coastaljag98's Avatar
Default High pitch whine
At idle from front of engine I am getting a high pitch whine. Goes away if I hit the accelerator but if i let off comes back. Not the fans and changing belt didn't change it. Waterpump? I have no leaks...
Old Apr 8, 2013 | 02:29 AM
Brettl's Avatar
Probably one of the tensioners the bearing will go bad.. I have to do the same on mine. Swap out the water pump while in there it's not that expensive of a part to replace ( metal fins )
Old Apr 8, 2013 | 07:24 AM
I have one new tensioner web I changed the belt. Hope it's not one of the main pulleys
Old Apr 8, 2013 | 04:02 PM
Bump. I have a video of the noise but don't know how to post it.
Old Apr 8, 2013 | 10:02 PM
Brettl's Avatar
If the tone changes when turning on the AC it's most likely a tensioner. That s how I found mine. If not listen for specific parts.
Old Apr 9, 2013 | 08:47 AM
OldMike's Avatar
Just for another point of view, you might consider taking it to a Jaguar dealership and ask them what's wrong with it -- they might have some pinpoint ideas that will get you on the right track. Of course, when they tell you it'll cost you $5 billion (with a "B"), you can tell them you'll have to think about it.
Old Apr 9, 2013 | 10:11 AM
Brettl's Avatar
The will probably charge for the estimate unless they do the work.
Old Apr 9, 2013 | 11:57 AM
OldMike's Avatar
I've never had that happen to me -- other than when they read codes they like to charge you! However, even if they charge $100 (est) to check it out, it could be money well-spent.
Old Apr 9, 2013 | 06:09 PM
We don't have a Jaguar dealer near. I'm in the Panhandle of Florida but it doesn't have thst screechy noise like bearings but maybe could be alternator? Ac compressor doesn't make any diff in the noise.
Old Apr 10, 2013 | 11:47 PM
TimA's Avatar
An alternator going bad will make a high pitched whine.
Tim A
Old Apr 11, 2013 | 11:44 AM
stran0020's Avatar
fuel pump going bad will cause a high pitch whine
Old Apr 11, 2013 | 06:02 PM
Bug Splat's Avatar
Get one of those automotive stethoscopes and start touching different parts. I use mine all the time and it has always helped me pin-point the noise.
OEM/Mechanic's stethoscope (25210) | Automotive Stethoscope | AutoZone.com
Old Apr 11, 2013 | 09:28 PM
Fuel pump is new. This is in front and seems to be coming from thst area of alternator.
Old Apr 12, 2013 | 12:46 PM
stran0020's Avatar
maybe just some belt dressing?
Old Apr 12, 2013 | 05:36 PM
Never ever ever use thst stuff lol
Old Apr 12, 2013 | 06:24 PM
jimlombardi's Avatar
Advance Auto Parts also sells the Automobile Stethoscope - Autocraft Automotive Stethoscope for $9.99. I just ordered one online and apply discount code P20 - 20% off site wide no minimum. Savings $2.00 No shipping - just pickup at local store - from the in store shelf.
Jim Lombardi
Johncy2000
Oct 2, 2015 01:05 AM
Glenn Barickman
Oct 1, 2015 04:09 PM
mrplow58
Sep 30, 2015 08:56 AM
gunlocators
Sep 30, 2015 08:05 AM
