humming sound
Old Jan 15, 2010 | 11:50 PM
alckc's Avatar
Default humming sound
My 98 VDP developed a humming sound and low grade harmonic vibration while driving. The best description that I can give is like I have all-terrain 4 wheel drive tires on. It is especially noticable when I am crusing at 30 to 40 mph. The noise ceases at a dead stop.
I checked the tires to see if there is a bubble or defect, but did not see any. The car otherwise seems to drive fine.
Any suggestions on the cause and solution.
Old Jan 15, 2010 | 11:53 PM
alckc's Avatar
Default sorry posted my inquiry in the wrong section
Old Jan 16, 2010 | 05:59 AM
Jagtec1's Avatar
It is possible that the inner edges of your tires a cupped, causing a noise. You may also have a faulty hub bearing.
Old Jan 16, 2010 | 08:01 AM
Thermo's Avatar
Veteran: Navy
alckc, sounds like you did the first thing in checking the tires for any tread separation/cupping. Next, while driving the car, when you make highway speed turns (say for an off-ramp or a curve in a highway), does the noise go away/change? You will need to do this for both directions. If the noise changes/goes away, then that is leaning towards a bearing problem. Finally, rotate the tires front to back and back to front. Does the noise change? If so, then that is confirming a tire problem. As you are rolling the tires around, do a good look at both the outside and inside portions of the tires.
Let us know what you find and we will go from there.
Old Jan 17, 2010 | 03:15 AM
alckc's Avatar
thanks for the suggestions. i will check it out and let you know. i had the bearings done about 8 months ago (hopefully the shop did a good job).
Old Apr 10, 2010 | 01:15 AM
alckc's Avatar
Default update
I finally resolved the humming sound on my 98 VDP. My own assessment were the wheel bearings. However, I have been busy with work and travelling so haven't had time to tackle the problem. The noise have been getting louder and vibration worse.
I took my car into the dealer last month who did not know what was wrong stating that I had to get an alignment first before they can accurately access the problem. I got the alignment done and took it to an independent this week. I told the mechanic that I think it was the bearings. Few hours later the mechanic called and confirmed that both front wheel bearings were shot. (I had the right front replaced last year).
Total cost $707. About 180 for parts and rest labor.
Rides a whole lot better now. Another problem done. Still more work to be put into the car...........
Old Apr 11, 2010 | 01:35 PM
Leedsman's Avatar
That mechanic must like to dine on caviar. Which illustrates the value of websites like this, making the cost of running a Jaguar a little cheaper for those who can 'do it themselves'. Wheel bearings for Jags. are not gold-plated, I don't think they're any different than any other car -- apart from one thing of course, THE PRICE! And I'll bet someone on this site knows an alternative wheel bearing that works ok for a lot less money.
Leedsman.
Old Apr 13, 2010 | 03:15 AM
alckc's Avatar
Yes, it would have cost a whole lot less if I changed the bearings myself. Bearings about $125 left and front, abs socket tool $150, about 3 to 4 hours of time since I would have to press the bearings out and back in.
boiler
US Southwest
Dec 20, 2025 12:38 AM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
Rocky15
Sep 28, 2015 04:59 PM
Long Islander
Sep 27, 2015 03:45 PM
