Information center doesn’t change with button press
Old Apr 11, 2025 | 05:10 PM
aquifer's Avatar
Default Information center doesn’t change with button press
1998 XJR. The information display in the center of my dash displays only the odometer setting. Normally when you press the button on the end of the turn signal stalk, you can rotate among different information. My preference is miles to empty.
When I press the button nothing happens. It stays on the odometer reading.
I reset the system twice by removing the negative battery cable and touching it to the positive for 15-20 seconds, figuring that would fix it. Nope.
Do those buttons go bad? It’s not like it sees much use. I do have another turn signal stalk assembly. Maybe I’ll end up plugging it in to see if it works.
Any suggestions before I dig deeper? Thank you!
Old Apr 11, 2025 | 05:16 PM
Addicted2boost's Avatar
Possibly the wires at the base of the stalk have broken off. Take the column cover off and look underneath the base of the stalk to see if a wire has come off. It’s not uncommon.
Old Apr 11, 2025 | 05:40 PM
motorcarman's Avatar
The multi-fuction switch wires are soldered to a terminal board and they become DISCONNECTED with headlamp MAIN/DIP and TURN SIGNAL operations.
Wire fatigue can break the solder joints.
Old Apr 11, 2025 | 06:56 PM
RandyS's Avatar
This kind of malfunction always makes me wonder how it could have designed and
constructed such that this would not happen. As long as I have been working with
electro-mechanical devices, i have seen this situation repeatedly and it occurs to me
that a simple bypass wire would have prevented the situation in most cases. Of
course, it would have also raised the building and material cost.
Old Apr 11, 2025 | 09:05 PM
Thanks Bob! I had no idea! 😂😂
Old Apr 11, 2025 | 09:13 PM
aquifer's Avatar
This sounds very likely. I’ll dig into it when I get a chance. Thanks for the advice!
zhaniJaguar
XE ( X760 )
Mar 1, 2017 06:16 PM
Johnken
Oct 29, 2016 10:50 PM
louvit
Jan 25, 2016 07:10 PM
mikesmith2
Apr 7, 2014 11:45 AM
mrtalkradio
Jun 28, 2012 01:33 PM
