Injector Electrical connections--How to undo
Old Feb 5, 2019 | 05:05 PM
Carnival Kid's Avatar
Default Injector Electrical connections--How to undo
I'm in the process of replacing the two notorious under-the-intake-manifold heater hoses on my 2001 XJ8 VDP. But I don't know how the electrical connectors to the individual fuel injectors disconnect. I see the wire clips, do you squeeze the wire clip to release the connector, or do you pull the clip away to release? I don't want to break anything, so thought I better ask first.
All input appreciated, photos would be a bonus!
Old Feb 5, 2019 | 06:22 PM
Lady Penelope's Avatar
By pressing the long metallic bar to the center or just squeezing , this forces the D shaped clips down and outward away from engagement
This is a EV - 1 type connector
Old Feb 5, 2019 | 07:57 PM
Thank you LP, I assumed as much but was way too unsure to rely on assumption!
I try again tomorrow.
Thank you again.
Old Feb 5, 2019 | 09:52 PM
SteveXJ8L's Avatar
The metal clips can also be popped loose. A gently pry underneath with a small screwdriver pops them up and "unlocks" them without completely removing them.
-Steve-
Old Feb 6, 2019 | 02:21 AM
anduha's Avatar
Just have some long tweezers or a magnet handy if one goes flying with this method or worst of all, goes under the intake manifold.
Old Feb 7, 2019 | 07:50 PM
Thank you everyone for your inputs..............once I pressed hard enough (with confidence gained from advice posted here) the connectors "click" undone. I guess I was just being too cautious, some of these Jaguar electrical connectors are crazy fragile and I am so careful not to break them for fear of consequential problems galore!
Old Feb 8, 2019 | 12:27 AM
Ltd's Avatar
Ltd
Default Injector connector
if you need a replacement, RockAuto has them
nasdaq6
Nov 29, 2017 04:58 PM
Florida_Pilot
Aug 25, 2016 11:44 AM
Red October
May 8, 2013 08:28 AM
Robinb
19
Dec 21, 2012 10:36 AM
loaks111
Jul 10, 2008 10:18 AM
