instrument cluster
Old 12-21-2012, 11:30 AM
Roy's Avatar
Roy
Roy is offline
Default instrument cluster
does anyone know how to remove the instroment cluster or better yet change the light bulbs in it
Old 12-21-2012, 11:44 AM
jimlombardi's Avatar
Received 1,620 Likes on 874 Posts
View post# 1 in the following XJ Range Instrument Cluster Removal & Install forum thread
https://www.jaguarforums.com/forum/x...r-i-faq-57772/
Also this other forum thread - view posts# 1 thru 8:
https://www.jaguarforums.com/forum/x...not-lit-72902/
Jim Lombardi
Old 12-21-2012, 12:39 PM
Hi Roy
Here is a photo of the back of the Instrument Cluster (old one we replaced with a used good one):
https://www.dropbox.com/s/ehjetryco7...%20Cluster.JPG
There are 4 large bulbs and 4 smaller bulbs. You need to turn the bulbs counter clockwize to remove them. I show 1 bulb turned counter clockwise in the photo (the large bulb in near center right part of the photo).
You just turn the bulbs and they release and come straight out.
I used needle nose pliers to remove the smaller bulbs.
Jim Lombardi
Old 12-21-2012, 05:53 PM
Safi's Avatar
wait so what are the size of the smaller bulbs?
Old 12-21-2012, 09:40 PM
Not sure this information is of any help, but this is what I found out:
The small bulbs are for the odometer and warning lights - Jaguar part# LJA4390AA Superceded by XR83865 (Osram part# 2351MFX6) 1.2w -- Looks like these part numbers are for the bulb holder & bulb?
I will bring my old instrument cluster into advance auto parts and ask them if they have a replacement for these bulbs.
Jim Lombardi
Old 12-21-2012, 10:52 PM
Tirefriar's Avatar
Default LED back lighting
Jim Lombardi
Can the instrument cluster lighting be improved by switching large bulbs to LED? Here's a thread from the Alfa forum on how to make the dash brighter:
Brighter Instrument Lights – My Solution - Alfa Romeo Bulletin Board & Forums
Not that X308s have the same lighting issues (Alfa dashes are practically blacked out at night), but would be nice to get a crisper back lighting.
Old 12-22-2012, 09:48 AM
Sean B's Avatar
Received 1,354 Likes on 1,065 Posts
I've tested various led's with my IPK - the bulbs run 5V from Jaguar, so the effect of automotive 12V led's is a dimmer/ similar brightness - not brighter even with the dimmer rheostat turned right up. I think 5V led's would be nice to find but I'm about done with my whole interior in blue led conversion...the large are W5W and the smaller are the same push fit but I think are called T5 x4 of each as already mentioned.
The one warning light I've got missing is the side/marker light, I think it's a burnt out led, not a replacement bulb I didn't look when I had it apart to install my Realgauge...something I might address...
Tirefriar (12-23-2012)
Old 12-22-2012, 10:06 PM
pod184's Avatar
When you do get the cluster out, it is a good idea to remove and reinstall each bulb, even if it was OK before. I had to remove mine twice due to a dodgy electrical connection on bulbs.
mhamilton
10-08-2015 02:17 AM
mrplow58
09-30-2015 08:56 AM
xjrjag
09-24-2015 10:08 PM
AL NZ
09-04-2015 08:39 PM
Quick Reply: instrument cluster
